Battery 'thought'
TJDIV
UP of MI.
Mod Emeritus
UP of Michigan
Website
www.roamwherever.com
With a brand new optima going dead, and discovering the cables loose (not crazy loose, but moveable by hand) at the terminal....
Is it safe to assume that the problem is the ALT not charging back the Battery due to bad connection, and that replacing the terminal ends with new tight [yes!!] fittings would potentially cure this BS?
Truck runs/ran fine otherwise.
No VLT drains that I'm aware of, the ALT 'seems' weak, headlights a little (not much) dim, might just be the bulbs..??..
I'm hoping I'm right. :doh:
That's what I'd do. Clean and tighten my contacts. I think I'd look at all of them between the alternator and the battery.
get it tested at your local auto shop thell tell you what the prob is, just dont buy stuff from them
check for voltage difference between the B+ (ring) terminal on the alternator and the (+) post of the battery, with the truck running.
Place positive lead of the multimeter on the B+ terminal and negative lead on the battery post. Should definatly be a positive reading of ~ 1 volt.
