Try a larger air line, and maybe removing the air regulator. Your existing line being short helps but still may be restricting airflow, which makes everything after the very first "impact" much less forceful.
Ok,
Now its desperation time. Nothing's off the table.
I have a FJ60 w a 2F & manual transmission (with heavy flywheel).
Although the 2F engine is very different than yours, I think the method I used to loosen my crank pulley nut is worth a try since you haven't tried it yet, and it worked for me.
I don't know if you can set up the wrench like I did on your 80, but if you can, this method was a success for me. Link below-
Whoa! I'm having crank seal woes...
Did you also try to tighten it with the impact wrench? Sometimes if you tighten then loosen magical things happen. Also hitting the bolt face with a hammer can sometimes work.
Next things to try:
- CRC freeze off then hit it with the impact
- Propane torch until hot then hit with impact (who knows, maybe someone did this before and used loctite)
It'll be noisy but you will have to full throttle that impact wrench for a while.
These situations remind me of the safe break on Bad Santa. Throw everything you have at it with apparently no progress and just one final tap and it pops open. Good luck man!
