Is there a ball that mounts behind the reverse light switch, in the transmission, on a 1978 fj40?
Not that I remember; the reverse shift rail moved directly into contact with the ball that was captive in the switch assembly.
In the meantime
Here's a teq that I removed from my 76 FJ40 H42 . I don't remember if it had a big washer.
This was in my 74 FJ55 4speed and it did have a washer installed. I've no idea if it's a teq switch or factory spec washerView attachment 1407759
I believe my 76 tranny has low miles on it. Guessing the piggy switch is worn down from higher mileage. You can see the tit is long
Sweet Forty BTW
That aftermarket replacement switch looks correct Deo man.
With the new switch installed, using the crush/sealing washer, the lights are still flickering in 1-4 gears?
"ball"
"tit"
