Bad Booster signs?
So let me resurrect this because now I'm having problems - when you say to press the pedal down, start the engine, then turn the engine off and the pedal isn't supposed to move - that means when you let your foot off the pedal it doesn't come back up to it's normal position? So you're saying that the vacuum in the booster holds the brakes on? I'm confused...:confused:
I'm getting a hissing AS I push down on my pedal...my idle changes and gets uneven if I'm pumping the brakes, and the brakes pump up while the engine is running, all of which indicate to me in my limited experience that the booster needs to be replaced. Can anybody give me a yea/nea or even a maybe on this? I've already paid for the booster and can exchange it if it doesn't work, so if anybody tells me to go give another one a try (FJ60 worked pretty good at least as far as bolting up) I'll do it :hillbilly:
I assume that you checked the rear of the MC for leaks into the booster. This is probably the number one reason a booster goes out. I would be curious what issues a 92-94 LandCruiser booster would have as the MC from those years is a direct bolt in on my 78 booster and eliminated the need for an external proportioning valve for those that have converted to rear disks. The MC for 92-94 is already proportioned for four wheel disk brakes. I would be curious if any one has tried using that booster as a replacement.
Subzali - what they mean, is that when you turn off the engine with the pedal still pushed down, it won't go down further with the engine off. A properly working booster should get your pedal down as far as possible when you push on it. If you can get more pedal with the engine off, then your booster is bad. The theory behind a booster is relatively simple. It uses a vacuum and atmospheric pressure to push on the master cylinder to amplify your pedal action. You can go to http://auto.howstuffworks.com/power-brake.htm to get a better idea of how a booster works. A hissing sound as you apply your brakes is a pretty good indicator of a bad booster. Also, when you say your idle changes with pumping the pedal, I would again say it was a bad booster (i.e. vacuum leak). If you have another one, I would hook it up. It is a relatively easy swap.
Good luck!
dustin said:
The Taco booster works awesome. Do be sure to grab the spacer if you pull it from a junker, or you will need to space it about 1/2" from the firewall some other way. I used nuts because I am cheap :)
What year Taco did you use?
98 *should* work as stated above, but I'm not 100% as i haven't done it myself. judging from the cross referencing in parts numbers at major parts sotores, it should be the same. The pic above looks like it will fit, and others have said they have done it. You probably need the factory firewall spacer though or you'll have to come up with a funky washer system.
time to re-resurrect this thread. I am in the process of replacing my 78 FJ 40 booster. I have a choice between a 90 2WD p/u and 94 4WD p/u. Will they both work? The 2WD is cheaper (easier for them to remove!). They look different, but if they both work, I'll save money.
Try it and see. When I went through this the various Toy and even Lexus boosters were nearly indistinguishable. I ended up with one from an 80-series Lexus for $50. I was looking at FJ60 & 62 ones as they were more common. One work of caustion...if you get a booster form a 62-series, make sure you get the external check valve as others have mentioned. It is in the line between the booster and the intake and not internal as is most everything else I found.
I know this is old thread, but what brake booster did you end up going with on the 78 FJ40? Thanks
