Backup camera question
musthave
All maps, one app!
Supporting Vendor
Florida / Colorado
So, I have an alpine unit coming in the mail, just bought a backup camera to go with it.
What is the best location to mount backup camera? Rear spoiler? By License Plate?
It's not wireless, so what is the best route to run cables?
license plate area. and the wires can be ran under the front rockers, and then behind the door panels. they pop off pretty easily and will allow for easy wire routing.
Best position is on the front bumper. That way you can see over the hilltops/obstacles that are below your field of vision over the hood. I have installed these in 2 rigs. Saves lots of hassle when you can't see where you are going. John
I might get a 2nd one for the front, but I have to figure out the back one first.
Has anyone made use of the rear window washer port is? Seems like that would be a perfect spot, just do away with the rear washer.
Bringing this back to life...I had the same idea for backup camera location. Or even where the rear wiper mounts. Only problem with that is a not sure what guts I need behind the wiper (inside the hatch). Has anyone mounted the camera up there?
If you have a rear mounted tire carrier then you need to reevaluate camera mounting.
I have myself a backup camera mounted under the license plate, and it's quite tricky to appreciate the distances…but once you get used to it it's ok. You can very nicely route it along with the license plate illumination harness. It also gets really dirty in bad weather conditions:pig:
