I searched but did not find my specific problem.
Heres the info: 72 FJ40 with F engine. New Rochester 2bbl carb. Did not seem to be running at full potential so I have since done the following: New feul filter, new plugs, wires, dist. cap, checked points. I can't get the srew out that holds the condesor on yet so I have not changed it. I adjusted timing to manufact. rec. 7 deg btdc.
The problem is that since I have adjusted the timing, which was the first thing I did, it is bacfiring out of the carb. It only backfires after it warms up and the choke opens. Specifically, it only backfires when I give it a lot of gas, let off quickly, then gas it quickly. It sputters and then POW!
The timing is set diffently than it was when it didn't backfire. But, I was trying to set everything to factory specs.
It starts right up and runs good other than the backfiring. Any ideas? I need help!!!
