- Joined
- Jan 25, 2011
- Threads
- 31
- Messages
- 217
Just replaced my CVs with CVJ axles, D/S went in without issue, snap ring on P/S seems a little too thick to slide in all the way, do they make these in slimmer thicknesses?
T= is thickness. I just buy an assortment.
43420E RING, SNAP (FOR FRONT DRIVE SHAFT) 90520-31005 T=2.8 90520-31006 T=2.6 90520-31007 T=2.4 90520-31008 T=2.2 90520-31009 T=2.0 90520-31010 T=1.8
| 43420E | RING, SNAP (FOR FRONT DRIVE SHAFT) | ||
| 90520-31005 | T=2.8 | B | |
| 90520-31006 | T=2.6 | C | |
| 90520-31007 | T=2.4 | D | |
| 90520-31008 | T=2.2 | E | |
| 90520-31009 | T=2.0 | F | |
| 90520-31010 | T=1.8 | G |
Yupp, all oem with the exception of the spindle nut. Using the trail gear setup for that. This does not affect the axel placement in the flange though.Are you using all Toyota OEM parts?
If everything is properly installed and seated, that's the only variable that comes to mind.
Pictures of this "trail gear setup"?Yupp, all oem with the exception of the spindle nut. Using the trail gear setup for that. This does not affect the axel placement in the flange though.
In a properly assembled pure stock wheel hub set-up, with OEM FDS (AKA CV). Snap ring gap, to narrow, for anything less than 2.2MM or thicker (97% of time 2.4mm or 2.6mm). Something is wrong.
Some possibilities:
- Outer axle of FDS, not pulled out far enough. Most time because grease, between brass bushing and FDS axle stop and or excessive grease in this cavity.
- Seal in back of knuckle and or seal on FDS, not mating as designed. Due to being bent or non OEM.
- Face of wheel hub and hub flange seat (area where gasket between them). Are beat up, to point hub flange will not seat flush.
- Non OEM hub flange gasket (to thick) used.
- Oil seal, in back of wheel hub. In backward. This gives a false breakaway preload, as seal protrudes, hitting inner backside of spindle. Thus, wheel hub can not press back fully on spindle.
- large (rear) wheel bearing outer race, not seated fully in wheel hub.
Some possibilities:
Here’s the linkCan you provide a link to that? Is it something like this?
Did the instructions mention using one less washer maybe??
Hub seal correct.What did you set breakaway preload to (lb)?
Is hub seal in correct?
Correct
WrongView attachment 4110331
What did you use to pull axle out , then spin wheel, to settle grease.
View attachment 4110335View attachment 4110334
Did you replace wheel bearing?
Did you keep all wheel bearing with their races?
Good points.In my recent experience doing this job, the hub flange and hub flange gasket made the biggest difference between the snap ring fitting and not fitting.
Whoever did my hubs last time bodged it. The spindle nut was chisel-torqued, there were 2 gaskets under the hub flange, and that extra thickness was dealt with by hammering the hub flange down.
If you have not already:
1. Check the mating surface of you hub flange for flatness. The hammer strikes on mine created a lip that prevented it from seating. Some Emory paper on a flat board corrected that.
2. Make sure you’re using a single gasket, OEM. An extra one will push your flange out .5mm - enough to prevent the snap ring from fitting.
3. Aftermarket hub flanges may be dimensionally off, so use OEM, but I’ll assume that if yours fit before it should fit again.
4. Scrape the hub’s seating surface flat
You want to get rid of anything that adds to the hub-gasket-flange stackup. I’ve read here that some folks use RTV instead of the paper flange gasket, which will create a shorter stackup, but that’s a bandaid fix.
You mention restoring mating surfaces, but not replacing hub flange. It these hub flange get deformed by BFH. I just replace them.Hub seal correct.
I used cruiser patch tool first, but didn’t work well for me, so used a bolt and carefully worked it in and out using a bolt in the axel and a pair of pliers on the bolt until it was mated on the brass bushing. Confident it is seated.
New bearings, races, seal, gaskets, brass bushings, needle bearing, flange bolts/nuts/cone washers etc. Did not replace knuckles or hub assembly but did flatten mating surfaces for ball joints where someone else used a bfh. Everything else was in good shape.
Preload was set at ~14. Will revisit that in a bit after I’ve rolled around a few miles to make sure it remains the same.
I ended up pulling it apart and removed the paint from the machined surface on the knuckle though I don’t know that impacts anything. Re seated the ball joint, stays in the lca but doesn’t take a lot to get it out. Put it all back together and was closer on the needed clearance. My temporary solution was to file the snap ring a bit to get it to seat in the groove with needed clearance. Will run it for a bit and check to see if things settle into place. Need to order some more F/G snap rings. Have a set of the remaining sizes. Guess we’ll see how it goes.
