Aussie locker install: which thrust washers?
Vancouver Island
Website
4wdtraveller.blogspot.com
I just phoned a dealer to order some replacement thrust washers for my 2H for the Aussie locker install, and they asked me which ones I needed, exposing my ignorance far too quickly for my liking. (I had no idea there were 2 sets of thrust washers inside the diff)
Anyway, I said I'd check with those who know before placing an order (always a good idea) so here I am.
Anyone know which thrust washers are the ones that often need replacing during a locker install?
Thanks...
You should measure... Or if you can't have the rig down for that long buy both so install is easier. If I had to guess I'd get the thicker ones.
You could use the existing ones in there depending on how worn they are. It's only going to cause the lockrite to click more often and wear faster initially if you have too much space. I didn't bother to replace mine I was satisfied with the existing thrust washer clearance upon install.
You need side gear thrust washers ... maybe
Thanks...
There are thrust washers for the spider gears (replaced by the locker) as well as side gears, and it's the latter that can be worn and lead to locker unhappiness if the clearance isn't within spec. The installation instructions explain how to check. HTH & good luck.
Why do you need new thrust washers? Do the clutch disks wear and require periodic adjustment of thrust washer clearances?
I'm trying to remember the process for determining required thrust washer thickness.
I'll check my ARB install instructions.
Thought my EZ locker and Lockright install ( years agoo ) I didn't remember thrust washers was used .. actually both locker was pretty tight in my 3rd member and need to lower the both side axle caps.
You need to measure what thickness you need, if any. There are various thicknessess available.
And to Stumpalama, nothing to do with ARB installation here.
I reused my old ones and the locker was at the limit for center gap (big). It was quite clunky. I have since purchased new side thrust washers and they were exactly the right thickness to get the center Aussie gap to the tighter spec.
I have not reinstalled it yet, but I anticipate the locker working much more smoothly. I got the new washers/shims fro the Toyota dealer.
There is a thread somewhere with the specs and part#'s...
Edit - found some
https://forum.ih8mud.com/80-series-tech/119066-aussie-locker-follow-up.html
https://forum.ih8mud.com/60-series-wagons/176496-aussie-locker-clearances.html
https://forum.ih8mud.com/40-55-series-tech/58648-aussie-locker-clearances.html
FYI - I bought the .083 shims
Yes, well, you can't know if you need new thrust washers or not, before you start the assembly per instructions and measure the clearances.
Altough not Yota site, and not Toyota axle, this Classic Broncos .com - Tech: Aussie Locker install - Dana 44 * 66-77 Early Ford Broncos has good pictures of installation and measurin tolerances, measuring is about half way down the site.
And, on 60 you don't have to remove ring gear, and if you have semi floating rear you are dealing with, you don't have to remove the third member. Side gear thrust washers are the ones in question.
I didn't need new thrust washers, but I needed new pinion shaft.
I am clear on the fact there this has nothing to do with an ARB, :D I just mentioned it 'cause the ARB install instructions are a bit clearer than the FSM on the c-clip thrust fit measurement. However I don't think that is what he's looking for.
Now I know... Dan I had some spare thrust washers from my ARB install, but they're gone now, sorry.
I too reused mine. So far no clunking or unnecessary "ratcheting".
At first the ratchet seemed really noticeable or audible. After discovering and tightening a loose pinion nut, it is extremely quiet now. Almost have to roll down a window to hear it now.
I am about to receive my Aussie Locker for my HJ60 and had the same question.
I called the Aussie Locker people in New Jersey (?) and the engineer said that you can't tell until you are installing. He then said that only 1 in 10 Toyotas need to add new side gear thrust washers.
I will be having my install done by Ciaran Wilson in Langley and don't wish any down-time while he is working. So, I ordered 2 of all three sizes thru Dan at 4wheelauto.com. The cost is about $13 each (same as thru Toyota dealer). Total cost over $100.
HTH,
Bruce
i re used mine and have had zero problems when my aussie was in the rear (over a year as a daily vehicle with over 15,000 miles clocked that year alone) and no problems with it being moved up front now either. It works great all the time every time.
I personally see no need to change them unless they have significant groves or very very very poor maint of the difs (as in never been changed in 200,000+ miles)
Well, I finally get to attempt the Aussie Locker install this weekend (I've earned an all-day pass from the wife). I'm optimistically hoping for a Saturday install and a Sunday trail test.
However, having never been inside a diff before, this might be mighty optimistic indeed. Still....how hard can it be, right? Right....?
PS: A cooler full of beers and I will be in my front yard working on the rig on Sat...any skilled and otherwise unoccupied Cruiserhedz in Vic are welcome to swing by...
It is easy to do, couple hours max. However, PLEASE, double check that your C-clips are seated properly during re-assembly. If they are not, your wheel will want to liberate itself from your truck. Ask me how I know...:doh:
It will be fine. I'd never done anything with a diff and have limited wrenching skills. It took me longer than it should have but now I could probably do it pretty quick. Post up if you run into problems. Make sure you measure tolerances when you install it. Oh, and when it says move the axle in, all you have to do is push the brake (or tire if you didn't take the tire off) and the axle will move in far enough for the c-clip to come off. Also if the side of the locker doesn't smoothly go on to the axle initially, just work at it and it will go on.
:beer:
Sorry, one last thought. After my locker was installed, I noticed some feedback through the driveline, which is apparently common. You should grease the slip yoke on the rear driveshaft if you haven't recently. It should minimize the clunking sound.
IH8MUD.com Forum - View Single Post - clanking sound
:beer::banana:
