Friday plans
I am planning to catch the Friday 8:00 am ferry, so that puts me in Tsawwassen about 9:40 am, so I will miss you guys at Lickman if you are their at 10:00. Probably about 11:15 before I can get there. In any case see you at Lodestone. I will go through to Coalmount.
There is a 40% my AC might be working by then. I had to order a new pressure switch and expansion valve (from Toronto - no aftermarket) install it, pressure test the evaporator and recharge the friggin' system (again).
Removed it from the FJ yesterday and fabbed up the brackets today. I also worked on the 24V side today. Once again a RIGrunner went in, this time a 4005. This will be powering the 40 amp 24-12 convertor, the 24-12 30A battery charger, the PSU for the Mac Mini and the fridge. If there's a fire, I'm in trouble. Did I mention HOT water shower (assuming the 2H will get hot enough).
