- Joined
- Oct 15, 2003
- Threads
- 21
- Messages
- 277
Asian Carb on 1972 F engine. Carb was rebuilt about 1 year ago. Couple months ago I got thinking it had been too many years since fuel filter was changed. Swapped it out with an OEM Filter. Plugged it all back together and engine wouldn't start. When it finally turned over it choked and sputter and blew lots and lots of blue/black smoke (dark). Would not idle. Drove it around for 20 minutes, killing at every stop light. Finally it cleared and ran great for a couple weeks. Then, after running a trail a few weeks ago it started running poor again, not idling. By the time I drove home it was clear again. Couple weeks later it died on the rode and would not start for anything. Towed it home. Had someone pull the carb top. bowl had a bunch of red Moab sand in it. Cleaned everything out. wiped it all down and reassebled. Ran good again. Then tonight, died again. would not start. Had to compression start it and fought it for a couple blocks to get it home. Didn't mention when trying to start it when it's not running good, there is gas leaking out from the front of the carb. must be under lots of pressure. Running very rich. Window shows level of gas all the way to the top of the window. When it's running right the fuel level is 1/2. Carb had been desmogged long ago. There is a port out the front of the carb that I was told should have an overflow fuel line that runs back into the tank. Mine is capped at the carb. But this settup has worked for 6 years without a problem. Why the problem now? And what do I need to do?
When Kurt pulled the carb top off last week he thought everything looked good inside, float, jet etc..
Any suggestions appreciated.
Troy
Troy
