ARB Lockers - what air source...
Aurora, CO
I hit the search (and FAQ) but came up zero.
My lockers and 4.88's are on the way. I was told to forget the basic ARB compressor and after pricing the bigger ARB comp I decided to run a ViAir OBA system. This would provide the air source for lockers and tire inflation (yes I know it's slow) but now I'm not sure.
I found a decent price on the ViAir Constant Duty System but I realized that the pressure valve is set to come on at 110 psi and off at 150 psi. After some research I found that the lockers are designed for 85-105 psi. The last thing I want is trouble with the seals since they seem to have been problematic ( yes, I realize they have been redesigned).
I have considered running a different pressure switch (designed for 85 on - 105 off ) but that would seem to defeat the whole reason I wanted the top of the line system. Is anybody else running this system and what have you done to manage the pressure?
I really don't want to run C02 (and absolutely no belt-driven OBA) for my tires BUT if I did go that direction I would want to spend as little as is practical for a GOOD comp for the lockers ... is the basic ARB satisfactory for that single purpose?
and Thanks for help but I would appreciate if this stays limited to the discussion of regulating airpressure. (no sales pitches on how much you love your C02 setup or York ...I've done that research already :D )
You can run a dual regulator setup from one pressure vessel. From the compressor of your choice (electric, belt driven, what have you) into a storage tank of your choice, with a cutoff of, say 150 psi. From storage tank to filters; from filters to 2 regulators, one fixed, one variable. The fixed regulator should be set to the lowest pressure that the ARBs will reliably engage. You may have to do some experimentation, but I would keep it as low as possible to avoid seal damage. The variable regulator can then be plumbed to your OBA setup for filling tires, running air tools, blowing up stuff for the kids, etc.
Since the lockers don't use any real air flow, be sure to purchase a fixed regulator rated at a low volume. High volume (CFM) regulators will only regulate properly with air flow. It's possible to get a burst of tank pressure downstream which will blow the seals in the lockers.
Have a look at my web site. My OBA setup uses a York (very happy BTW ;). I use the ARB compressor for the lockers as it was already installed and reliable for years. I didn't see the need to change it. I also have a 1/4" quick disconnect mounted to the ARB just in case.
Thanks, my initial thoughts were about keeping the high pressure switch and trying to regulate the pressure from the tank to the ARBs but was concerned more about the hassle of additional lines and such .... never occured to me that I couldn't use just any pneumatic regulator. :doh:
After thinking it over last night I realized that some guys use high pressure C02 systems to operate their lockers and after some searching found kits designed to regulate the tank pressure down to ARB specs ... a little pricey but gives me some ideas.:idea:
I'll bet the York is nice to have but I just don't have the room :crybaby:
Can you point me to this info. I also have ARB and 4.88 on the way for my 94. I could not find info on the CO2 setups.
I just installed a York compressor using Slee's kit and run my ARBs off it. I kept it simple and used the ARB pressure switch. Airs up the tires quickly even with the 105 psi max. At this point I have no plans to setup a dual pressure system.
I bought the fittings and such to hook my Powertank to ARB switch at McMaster-Carr for less than $10. I just kept the regulator on the CO2 tank at 80psi.
