ARB Locker Switches
Scottsdale, AZ
Searched, but didn't find anything specific....
Was offroading yesterday, and for the second time in a few months, the ARB switches broke - that is, the crappy plastic tabs on the back broke. The result was me trying to make my way up a high angle slick-rock ramp, and when I went to hit the switch - Dang! Its somewhere around my feet! The f'ing thing fell off!
No, I am not hard on these, I just think they are cheap and need to be upgraded.
Anyway, I am now on a mission to find a different and better dash switch to operate my ARBs. For such a high quality (and expensive) item, I am surprised the switches seem to be so flimsy.
Anyone done this and have recommendations? Thanks!
Another option is to use pneumatic air switch for the air locker. This eliminates the need for the solenoid and electrical switches.
Contura (?) switches I think that is what they are on an ARB, anyone?
I have found them to be a great switch... check the marine applications for good switches too.
Rezarf <><
Contura III switches from CarlingSwitch are an exact replacement... You can find them at waytekwire.com and other places...
When I install my 2nd ARB I will be switching to manual valves, tryin to keep it simple.
I use one of those red lockout switches. To engage the locker
you must lift the cover and throw the switch. To dis-engage the locker
you just close the red switch cover. I was always afraid I'd accidently
engage those dang push buttoms going down a highway or maybe a
passenger would. I also use one for my air compressor.
LOL...people always ask what the switches are for and I tell them they
are for the rocket launchers. They are available from Summit Racing.
They work well and do prevent accidental use. The cool look is
just a side show. :grinpimp:
Try: summitracing.com
search for covered switch
I use summit a lot for my projects. I will check it out. Most of those I saw, though, are for 3 prong electrical connections - on the back of the locker switch there are 5 prongs. I am searching out my install guide to figure out what each are for.....
3 of the prongs are for the operation of the switch, two are to have it lighted at night when you have the headlights on
I don't quite see the issue with the new ARB rocker switches - the old push button style could become stuck
Thanks for the info. That is what I figured...
The issue is on the inside of the switch cover - there are 2 thin plastic tabs that hold the cover to the switch assy. They can break pretty easily. I have gone through two of them. Luckily, I have spares for now, but I want something more solid.
Thanks again, folks!
I had the old push buttons. They would get stuck and/or not work frequently.
You are aware that there is a special tool that MUST be used to remove the actuator from the face of the switch body, and that removing the actuator from the face of the switch and not using the correct tool will damage the actuator, correct?
Do you own this tool, and what does it look like?
Further on this:
If the actuator has been installed and then removed from the switch not using the proper actuator removal tool, there is a possibility that the actuator pivots on the switch body could be damaged as well.
These are a high quality sealed switch that has been used by many manufactures for years. They are far from cheap or flimsy.
You mean this tool? :grinpimp:
These are very good switches. I have used these for years. I will say this, the new curved hard plastic actuators that are available (NOT the ones supplied with the ARB locker) will pop off easier because the shape is easier to catch something on. I put these on my Xterra and have already had to replace one of them as it finally broke.
These are also the switches used on my Sea Ray boat.
That is it.
Caterpillar has been using these exact switches in open ROPS machines for years without issue....and ever since ARB went away with the push-button switch,(two versions, both did not like open cab trucks) calles for replacement switches have fallen to zero, other than folks wanting to replace old ARB switches with the new style.( this current style of switch started shipping with the compressors and lockers back in 1997, iirc.)
:beer:
