ARB Locker Question
Kansastitty
Just finished installing the ARB that Poser set up for me and I must admit it was plug-and-play, with one small exception. The Allen head bolt that secures the pin in place seems to be about two threads too long. The little threaded pin seems to be all the way home, but the Allen bolt bottoms out on the pin before it is tight against the lockwasher.
Should I shorten the bolt by 2 threads, use another washer as a spacer or have I done something else wrong?
He'p me:confused:
Ed
I can't remember an issue with either of mine but it makes sense to have the little capscrew locked. Another lockwasher won't hurt anything, and some locktite too. Don't get locktite on the throughpin.
I would be very suspicious that the pin aint in all the way. Try a small punch with some very light tapping to seat it. I have always used a piece of coat hanger to check depth of hole after cross bar is in , then I hold pin up to coat hanger and mark where it should be when in all the way. Check cause I have never heard of anyone modifying that cap screw. FWIW I have old style arb and new style ( one used allen bolt instead of cap screw ) and niether had this issue and I did check length . The allen was 2 or so threads longer but fit fine in either unit.
I am not familiar with them, but I'm pretty confident that they make them so that the screw doesn't need any grinding to fit. I would pull it back out and take a peek to see if something is preventing it from going all the way in.
I had something in my head about an 'L' shaped tool that was supplied in the kits but now I think that whatever that's about, it ain't ARB lockers.
Have you tried tapping the pin in, ED, as peesalot suggested? I'm pretty sure that that's all there is to it unless somehow something is down the hole. If you got it assembled from Poser I'd doubt that there's anything done sloppily, which is what someone would need to do to get that hole crapped up. So Tap on it, Ed, you won't break it. :)
Get ahold of Poser. He should be able to answer this question for you.
Go here see my pics at the end of the thread. You need to make sure the pin is fully seated. Take a phillips head screw driver and push the pin in fully. Been there, done that.
projektdotnet said:
Call Poser!
ditto,
or ARB directly - helpful folks !
