Any Problem With This 3 Link Setup?
Ambridge, PA
I want to do a 3 link setup both for improved flex and to be able to correct/adjust my camber.
Could I simply remove both front 2 radius arm bolts (leaving only 1 on each side) and cut the arm only leaving the ones further back and simply do a truss with an upper link out of DOM with bushings?
This just seems too easy to have not been done/thought of before and I've seen nothing like this, just people removing one front bolt to increase flex. So there's probably a reason it won't work, just like to know what it is.
And I want it to hold up to 315's and moderate abuse.
Thank you in advance,
Shane
Bump!
Firstly, I know nothing about 3 link suspensions, but I'll throw my knee-jerk response out there (at least you'll get a bump out of it :D).
The caster bushings aren't designed as a pivot and I would guess that they would wear fairly quickly. They don't have zerks like a Heim or Johnny joint.
If you haven't seen it before, maybe Shawn Jackson's FJ80 front 3-link will give you some more insight as to where the third link would need to be located and if it's doable or not.
Thanks for the reply.
I was planning on using leaf spring bushings for the upper link as they last a LONG time! they also flex fairly well (better than radius arms)
I have seen Action Jackson's 3 link set up. It is done wonderfully. I just don't have the time to make new lower links since it's my daily driver.
I my plan is to:
Lift it (no castor correction)
Fab the frame and axle mounts for the upper link
Fab the link (adjustable)
Then install the upper link and cut the radius arms between the 2 bushings leaving only one on either side (using them as lower control arms) and adjust the upper control arm for correct castor.
This way I will be 100% sure that my axle is located in the stock position under the rig (nice and square)
And also still be able to remove my lift (if I ever sell it which won't happen) and still retain correct castor at stock height as well as having it adjustable.
In my experience it wont work or wont provide more travel. On a lifted, caster corrected rig, the arms are very close to the tie rod. This works because the axle/caster angle changes with travel, so the tie rod to arm clearance remains close to the same with travel.
On a 3-link setup the caster/axle/tie rod angle stays close to the same with travel, the links swing up and down in relationship to the tie rod, so much more clearance is needed. The stock arms don't have enough clearance to work and have more travel.
Look at the clearance in these pix and note how far the rear of the arms are dropped/lowered.
If you end up cutting your radius arms, I want one of the bushings. :D
just throwing this out there but what if you made new lower links with heims out of dom tubing and just used the rear bolt with a third link, just a thought
Is there a way to possibly use DOM and go over top of the tie rod and bend down to the rear stock bolt location on the axle and then add a third link?
I have been thinking about this alot lately and how this could be done.
This is exactly what I have in mind, only using the stock radius arms as the lower links (by cutting them)
It seems like there would be no difference in the tie rod interference as with a rig with stock radius arms, a J lift and castor plates.
Because the lower control (modified radius arms) will be in the exact same location as the stock radius arms.
Am I confusing everyone?
Except that the three link is going to make the axle travel in a different way and cause it to stay more "in position" thus effectively tilting back when drooping so the tie rod will come into contact with the arms.
Also you would need to make sure you do some reinforcing on the axle side mounts to prevent them from cracking.
Slee,
Thank you for the input. I see where you are going with that, but doesn't the axle staying "in position" throughout the cylce of the suspention directly relate to the angle of the uper control arm in relationship to the lower contol arms?
I think that the upper third link, when the axle is flexing down, kind of pulls the top of the axle back when traveling down which in turn would rotate the axle assembly back causing the tie rod to hit the bottom links.
My question is what about going over top of tie rod and bend down to the back bolt? I think it would work because I do not think that axle will rotate as much with up travel as with down travel?
Does this make sense?
Links over or under the tie rod are pretty much the same deal, need about the same clearance to avoid tie rod contact. All 3link setups need vertical separation between the lower and upper links, so with the links over the tie rod, the tower mount for the upper link will need to be taller, would work best with a big lift.
Run the numbers/design in a suspension design program, I couldn't find a design that I was happy with. IMHO the tie rod is exactly where the lower links need to be. To do it correctly the tie rod needs to be moved to the front side of the axle or start with a different axle.
how do you go about moving the tie rod to the front?
What kind of set up would you need? High steer?
Search action jackson. I will be going this same route. Except one 1-1/4 heim and spacers on the axle end...big giant superride bushing on the frame end for my DOM .250 wall link. By adjusting link placement, angle, and length, you can get the axle to do whatever you want...how good are you at metal fab?? The posibilities are almost unlimited.
From the pics I observed of ActionJackson's setup, it appears that he left the tie-rod in the rear. How did it work for him as far as interference goes? I know he didn't use the stock brackets, but did his setup work successfully? Has anybody ever seen that rig in "action"; no pun intended.
Any other 3-link 80's out there?
