Rethinking bugsnbikes original post and idea - what if you made an open rack design for the rear, similar to what the jeeps use, essentially a shelf instead of an enclosed box. Design it to hold two of the medium sized Rubbermaid Action Packers, or three larger Pelicans, and use a steel bar to lock the tops down. That way you have lockable, watertight storage, and the plastic boxes can be pulled off and left behind for campsite use. The rack itself would weigh considerably less, and the sightlines would remain open. It could swing away and even be made to fit above/around an external spare or jerry can shelf. If you had the room, you could make an enclosed, lockable box along the bottom edge of the shelf that could hold recovery gear like straps and shackles, flashlights; essentially the first items you grab when you're stuck.
If you can design it to accommodate a pre-made box like ActionPackers (cheap) or Pelicans (not-so-cheap), you'll have less weight and mass as part of the structure, and it becomes more modular and flexible instead of one huge steel box.
