By the way it looks as if you have a really nice cruiser. Can I see the rest? You have a build I missed?
You want to confirm first that you in fact have 12v at the black wire with a yellow stripe coming out of your harness. It's the only wire you will need from your harness.
Assuming it has 12v it would connect to the positive terminal on an internally ballast resisted coil. The red wire from dizzy goes to the same post. Black wire goes to the negative side.
Ok, thanks for the feedback Marshall. But to be clear regarding the "blackwire with a yellow stripe coming out of your harness" was it originally connected to the coil positive post? The original wires show with loop connectors are all I see available - and this is how it run in stock form. The right loop went to the right post (+) and the left loop went to the left post (-) (there are actually 2 wires hooked together here).
So am I right in needing one of these wires or look elsewhere in the harness for the black wire with a yellow stripe?
