Decisions
Things have been a bit slow of late, a lull in parts deliveries has given me some time to reflect. As most of you know this is a learn by doing build for me. There is alot that I wanted to do myself but as a noob I find myself gravitating to the electrical as it most lends itself to my past DIY projects, PC's ,Laptops and home A/V. As such I decided that I want to tackle the complete re-wire myself. It flows naturally from the work I already started restoring the instrument cluster and frankly it is the one thing about the rig that pisses me off the most about how the PO treated it. Having said that the decision is about timing. Do I send the rig out to the body shop first and have them do the frame off sand and body beat and paint and then put the craptastic wiring back in as is or do I do the rewire first, knowing that they will pull it when they pull the body.
If I leave it til later I want them to put the craptasticness back so I can have a go-by, item by item, as I keep hearing that the wiring diagrams for the rig and the Painless kit instructions don't match up and I figure a visual, hands on go-by would be good belt and suspenders. On the other hand I could plunge in and do the wiring now but I don't want to take a chance of all the new work getting damaged by the panel beaters breakdown and re-assembly of the rig.
Any suggestions from folks who have done this with reasons would be appreciated.
After much research and discussion with mudders I have decided to go with a 60 steering setup. I decided this for several reasons. One I am having a 4"lift with a plan to run 35s (assuming I can find some here, so far three big tire shops, no,luck) so I need a stronger box and setup than the mini truck. I have my eye on a pretty good size winch (Hawkdriver is fabbing my bumper now with a few mods to make space for it he calls it "sweet") and I kept getting nervous about how far forward the Sagnaw setup was on the frame. Also probably my noobish imagination but it seems to me that if you have a choice why not mount something as important as the gearbox in a more protected/less exposed area if you have the option. Again could just be really wrong on this. Last, except for the steering shaft bit it seems that the full 60 ps setup is easier, I could well be wrong but I'm gonna find out.
That gets to the last bit on steering. While trying to figure out which ps setup to go with I took a good long look at the steering linkage and what looks like an impending knuckle rebuild. I'm definitely going to knock out the steering linkage myself as I will be right there at the pitman arm when I bolt in the gear box. As to the knuckle I'm not sure if I have the tools or the know how for that yet although I can read a manual as good as the next fella and will have the time.
If folks are snapping birfields as easy as they say, especially running bigger tires and ps, prudence is starting to tell me to learn now about knuckles and their innards sooner rather than later out on the trail somewhere. If you more experienced guys have a view on the wisdom of this let me know, as I said I am learning as I go and I welcome the advice.
Last, a word about mudders. Thus far advice and assistance from mudders has saved me close to $1,000.00 in this project. Additionally, a couple of mudders from this region contacted me today with ideas on sources for parts in the region, thereby probably saving me bundles in shipping costs as well as invites to hook up to 4x4 clubs in at least three of the neighboring countries when the rig is done. Finding this site was the very best thing I did. It is miles above any other forum I have been on for no BS focussed advice and information exchange and BTW you guys are WAY funnier than the members of the other boards. Thanks.
