And another issue, Output flange
Canby Oregon
Ok when it rains it pours, so changing, my new shiny rear drive shaft, and I am getting the shaft, one of my studs, has/does spin as I turn the nut, so the question is, do I need a new flange, or pressing new studs is sufficient ??
The stud is more then likely threaded into the flange, remove the bad stud from the flange to see if the threads on the stud are stripped. If the threads are stripped on the stud, just replace the stud, but if you've stripped the threads in the flange, then you'll need to install a thin wall thread sert.
Solid Threaded Inserts | Carbon Steel Inserts | E-Z LOK
KEENSERTS&#174 Thinwall Inserts On Automotive Fasteners, Inc.
And last here are some thread/stud thread serts
Studs On Arconic Fastening Systems and Rings
All of these inserts can be ordered with metric threads.
They are pressed in studs with a knurl, and are pressed into the flange, I will just get a new flange and studs, a nutsert would never hold it, it's the rear drive shaft
I guess we'll have to agree, to disagree, i wouldn't hesitate to install a thread insert, and threaded stud in this application with loctite RC680 retaining compound. Especially to save a customer the cost of a new flange, new lock nut, and the labor cost to R&R that flange. Anyway good luck with your repair.
Why not tack it?
Yes, tack it. Unless the threads are damaged and they need to change the stud.. When I was looking at a similar job I concluded that I had to remove the flange from the case to get enough room to get the stud in from the back.
Also, the flange is too thin for any of those thread insert solutions to work like the studs did, they don't make them in the correct thread, and good luck finding a bolt/stud of the correct grade and thread pitch to extend it through the driveshaft flange into the thread insert. Toyota used a finer pitch than even normal metric fine.. they are quite unique. And before you say you don't need to use the same pitch, your torque and clamping values would change, for a critical fastener like the driveshaft flange.
So.. if the threads are good, tack it. If not, pull the flange, replace the stud, and tack it.
x2. Having built more axles than I know people, this is the way it is. Tack welding wouldn't be my first choice. Remember this is a rotating component and it needs to be balanced, or close to it, or it'll bounce itself apart.
You're safer replacing the flange if you can't get a new stud pressed in.
If a metal booger throws your shaft off balance, it wasn't balanced right to begin with.
Well I will, tack it pull it and replace the leaky seal, and then just weld it in place, I know those fine pitch threads hols a lot, and I have used nutserts for many things, but nothing like this, and I probably never, I mean I could imagine what my Cummins would do to a nutsert :eek: . Thank you for the input, I was going to go that route any way
turbophil has been running on 3 studs with his cummins 10K+ miles, as one was broken. i think you over thinking it.
I have bad luck, so I make sure things are correct, I will pull it off, tomorrow and replace the seal, and tack/weld the studs in place
You don't have bad luck.....
The guy did a complete 6BT swap in like 4 hours so he can't be that dumb. OCD maybe...
It's not personal........
EVERY time I hear someone say: "I have bad luck." I either say that or post it for them.
My rear output flange has only 3 studs and all are tacked in...not quite sure why there are only 3, PO must have had an issue.
