Am I remembering correctly?
Sisters, Oregon
I have had my 78 FJ40 for about 25 years. I live in a climate that often sees near zero temps in the winter. Do I remember correctly that the heater heated up the interior well and my right foot would get uncomfortably hot. I am working on my heaters and I am trying to establish a measuring stick.
I only have the one heater in the front on my 1970 and yes my little toe on my right foot has gotten quite warm at times.
You might want to insulate the cab a bit (floor). At 0F, the OEM heater will be working fairly hard to heat the inside. You may want to run the rear heater as well.
At 0F, I don't think anyone gets 'uncomfortably hot' in an FJ40 at 0F, at least I didn't. You could always make a temporary cardboard deflector to divert the heat from your right foot.
I removed both heater cores and I had a partial restriction in the main heater core . I used some radiator clean out chemical and let it soak for an hour, then attached the garden hose to them and flushed and reversed flushed with hot water. While the cores were soaking I noticed that the duct that delivered the outside air to the heater core had a piece missing where it joined the heater housing. I taped it up with some 3M underground electrical tape for a good seal, then wrapped duct tape around it to make the connection stronger for installation. Inside the shop I warmed up the 2F engine and got 150 degree temperature heat at the ducts. I am sure that will make my right foot uncomfortable. In the colder conditions l also cover the lower half of the radiator. Can not wait to try it out tomorrow morning suppose to be near zero.
I wish I could get heat in my 40 I’m lucky if can even defrost the windshield.
Mine will burn me out of the cab in the winter, it takes a while to get the cab hot but once it is hot I have to crack a window. I have both front and rear heaters and I cleaned the cores pretty good before they were installed.
If the temperature is below 20º (and there's snow on the ground) I wear pac boots because I ain't getting cold feet if the truck breaks down and I have to walk home. I can't feel the heater through those. With lighter footwear my right foot can get a bit hot if the fan is on high but not on low. I also have the rear heater installed.
