I searched 'Mud before just posting a question, and found an old thread in 40 tech. I added to it in search of more info but would like to hear from more members. I am installing a new aluminum rad because the first Flexalite one didn't last a year in my non daily driver '40. With all of the net research I have done it came to my attention that electrolysis is a big concern when running an aluminum rad to cool an iron block/heads ( my intake is aluminum). With the info I have found online I do believe electrolysis was one of the main factors in the first rad's failure, combined with harsh driving conditions ( frame flex, and all-around gettting pounded on ). Also through this research I have come accross a sacrificial anode intended for automotive applications. Flexalite Part # 32060. A two inch piece of zinc that threads into a 1/4" NPT plug. See pic. I am now almost complete installing a new Becool aluminum rad. The engineering of the rad mounts has been reworked so as to preserve its life, including rubber isolation. Now, I am led to believe the location of said anode is irrelevant as long as it is submerged in the coolant. So if I locate it in one of the unused ports on my intake manifold it should serve its purpose and protect the intake manifold as well as the rad ? Furthermore, what are you running for coolant? Are you using Distilled water? Other additives? An anode? And any other tricks, procedures, or info you have to share would be appreciated. I know refilling/purging a coolant system isn't rocket science, but you never know what kind of tricks guy's (and gals) have come across. Thanks in advance.
