Alternator Relocation Problem
Philly PA
Ok here is the set up, I have a F, my buddy sent me a bracket from a 2F that moves my alternator to the passenger side. The bracket bolts on fine, holes are already there and line up perfectly, but when I put the alternator on it sticks out too far for the belt to line up. Any ideas whats wrong, we thought is should be an easy fit but it is a good bit too far foward.
Thanks
Tom
Do you have a 2 groove crankshaft pulley? I moved my alt to the pass side and it runs off the front groove on the crank pulley. I also put on a 2 groove waterpump pulley. The wide belt runs the waterpump and the PS pump and the narrow one runs the alt and the waterpump.
GL
Ed
Do you have it mounted like this?
Is it a stock alternator?
There isn't a wrong way to mount the bracket, so the only thing I can think is you've got a different alternator??
GL
Ed
I did the same thing for a 74 F engine. The alternator pulley will almost touch the radiator shroud.
My front pully was narrower than the back pulley for running the air pump I guess. I got a pully from Man-a-fre for a standard belt for the toyota alt and it moved it back about 1/4 inch. So far it works fine. I have the fat belt running the water pump and power steering.
How far out of line is it?
My 55 used what could only be described as a "short shaft" water pump. Yours may have been replaced with one of them??? But your water pump pulley and cranshaft pulley were in alignment...so that doesn't make sense. So much for Wild guess #984
I believe on the F you will need to run a long shaft water pump tp do this. This will move the double pulley on the pump out to align with the new position of the alternator.
Oh, and I had to use the little spacer to get the fan out of the belts, too.
GL
Ed
What would be a good source for the 2-groove pulleys and the pass side alternator bracket?
When I did my minitruck PS conversion I had to get the following to make it all line up...
'76 2F water pump w/o oil cooler
2F 2-groove water pump pulley (non-clutch fan) the one for the fixed plastic fan
2F alternator bracket
2-groove harmonic balancer w/ 2 wide grooves (not sure what year)
When all these pieces were in place everything lined up perfectly. Alternator on the outside and PS pump on the inside w/ both belts going over the water pump for redundancy.
Jody.
You might be able to move the alt back on the mount so that the front lug on the alt is behind the one on the mount and pack it out with spacers. I was looking at mine and it looks like that would move you back about an inch.
What year is your F engine. Actually more importantly, is your balancer pulley a double wide, or is the outer narrower. If it is the latter, then all you should really need to do is switch the alternator pulley to match. The 64 thru 67 alternators came with the narrow pulley, and a standard GM pulley will usually work too.
Not that I would want to recommend putting GM parts in a cruiser. :D
