All windows very slow in cold weather...
Denver, CO
I've noticed that when it's very cold out the windows (Pass and/or Driver) have very hard time closing up. Is this a sign of weak motor or some other problem with the channels that the windows slide on?!
In normal temps I don't notice it at all.
James
Many threads on this, do a search for slow+windows. But to answer your question, IME, variations of all you mentioned.
As Kernal said there are multiple reasons for this, personally I sprayed Dow Corning 557 silicone dry film lubricant down the channels and had great results. leaves no visible residue and seemed to do the trick. FYI i ran the windows up and down so many times the circuit shut down, just waited a few minutes and it reset, all was well thereafter. I do have to re-apply every few months so for sure there are more permanent fixes for this. Cleaning the contacts in the window switches, replacing the channels, replacing the motor, in that order seem to cure most problems.
I had tried all the usual tricks for a slow DS window which worked for a few years, lubing the runs worked for awhile, lubing the regulator, a bit faster, then replaced the runs. However the original motor was still weak even after completely tearing it apart, checking all the components (good), then cleaning and lubing everything. After a new motor, new runs, and a well lubed regulator; perfect.
Funny how when you replace all the old parts in the system it works like new again! Do you recall what the new motor cost?
I picked up a Dor_man motor from Vatozone, $55 with lifetime warranty (if you keep the receipt). Had to tap the mounting holes (they come unthreaded) and swapped the connector from the original motor to the replacement.
i have the same issues with my 80...word on the street is that a ford exploder pw motor bolts right up and is twice as fast...just sayin..
Man, I would have a really tough time putting FORD parts in my Toyota. But, if it makes the windows do what they should do, then I might be up for it if the cost isn't outrageous. You should try this and report back! In all the slow window threads I've read (believe me, I have read a lot), none have ever mentioned Ford motors.
I'd believe OT every ford I've ever owned has windows that are twice as fast as the next closest brand and they seem to go on forever
i would think the mid 90s i happen too have an exploded explorer at a buddies...i will yank them and give it a shot too see if the word is right...id hate too mislead everyone.. ill see how quick i can get at it stay tuned!!
Have had the same problem with my 1997 FZJ80 driver's-side window (and others). Lacking any better idea, a few weeks ago, I purchased a toothpaste-tube-like NAPA "Sil-Glyde" lubricating compound (stock #765-1351) and slathered it into the window's rubber weather seals. Seems to help quite a bit. (Also quieted a creaky kitchen drawer that had been bothering us for 10 years!)
would love to hear if the ford motor fits! Im not looking for speed really, just windows that work. Also id image the ford window motor SHOULD in theory be cheaper here in the states.
subed for ford pn
I went out yesterday afternoon and took apart the door to lube the window tracks and mechanism. After living it the window goes up and down better but it catches on the swollen hard track even when it's covered in white lithium. A stronger motor could push thru this better but I think swapping the felt track would be beneficial if the price is right for them.
typed badly on my iPhone using IH8MUD
