That's exactly what I did for the steering fluid. I used Toyota WS ATF because I already had a few quarts of that.I use Mobil 1 75W-90 LS in all gear boxes. Torque plugs, with new washer, to 36FT-lbf on diff plugs and 27ft-lbf on transfer case.
I use Mobil 1 ATF in power steering. Bleed wheel up engine off, than wheels down engine on. By simple turning steering wheel slowly stop to stop 3 times, hold at stops for 3 sec.
I'm draining the rear diff and I can't figure out the oil viscosity. I also am using a FSM for an 04, which mentions an LSD axle. Did the 98 LX 470 come with an LSD Option? Anyone know what the axle code is for that? This truck's axle code is A04B. Anyone know how to tell what that is?
LSD was standard on a 1998 LX. It should have a sticker that looks like this:
M1 full synthetic 75W-90 LS, is LSD rate. It and regular 80W-90 or 90W gear lube, is all GL5. Which LS works in all limited slip, and is fine for none slip. You just don't want a none LS in a LS differential.
M1 ATF is worth a try for ~$12, which is much cheaper than new vane pump. I love M1 ATF, in 98-02 transmission and 98- up power steering.
I have no such sticker presently.
I thought it was odd that you didn't see it - it's a pretty darn tough sticker.
When I first got my 99 it had that same lovely 12v Audiovox VCR up in the front passenger footwell. I'm assuming you also have the corresponding giant hole cut in your headliner for the overhead unit. Whoever the original owner of mine went to for the install was an absolute hack, when I had the headliner down to fix my sunroof I pulled out literally about 30 feet of excess cabling that was just shoved up there. I'd really love to find another headliner that hasn't been cut out so I can get rid of the damn thing. Anyone in the PNW, if you have a clean ivory headliner, PM me haha...
Nice save!
So is this truck gonna be shared?
