Build AK HJ-75
Big day today. Everything in these pictures hopefully are finished and in place permanently, I hope🤣
Wipers installed and finished.
Pedals and steering brace and HVAC ( or whatever one calls these in a car)
Brake and clutch
And heater valve
Might have a clearance issue with the steering column. I have about a 1/4” clearance with this bracket and water cooling line. I wonder how much the engine twists due to torque, both at start and while running. Any thoughts?
An update, I looked at the HJ61 sitting in my driveway and blipped the throttle a few times to see how much that engine rotated, and at start, and it hardly moved, so I am hoping that I will be alright as long as the engine mounts don't brake.
So now I got that end finished. Now for the through the firewall and attach to gas pedal. I ended up cutting apart the firewall end on my donor(rhd 2H) cable. I was able to pull the rubber part over everything. I had to cut the cable to get the firewall attachment parts off. Then trimmed the plastic piece to fit better. I had to cut half way through the plastic parts to slip the cable through. I also had to cut half way through the plastic lock collar for the attachment to the gas pedal. What you think? Does this look like it would work? I wanted a black cable but they didn’t have one in the length I wanted.
I did something similar with my cable. I shortened a OEM 1HZ cable and used the same end you used for the engine side. Drilled out also.
