There's a ton of information out there on installing one's new synthetic cable onto a winch. But none for the Aisin winch. Warns seem to tend to have a hole in the drum that the cable passes through, others have a little hoop near the bottom of the drum that you loop the cable through and then pass back along the drum.
http://www.winchline.com/documents/Viking Truck Winchline Instructions v1.2.pdf
The Aisin winch has a slotted hole in the side of the drum, that the wire cable passes through, and the hooks into a little sleeve thing welded on the outside of the drum. The end of the cable has a knob thing on it. There's also a small set screw (allen) that presses against the knob to keep it from popping upwards in the welded sleeve.
What is the best way to attach my new synthetic cable? The end of my cable has one of the electrical eye crimp in it, like this:
Good stuff Andrew! Its nice when a wheeling buddy gets good/new/better extraction tools.
Is there a rope sheath one can slip over the line for the first couple of drum wraps to increase friction? When Jay got his synthetic rope it had an abrasion sheath and a drum wrap sheath included. (IIRC)
Whatever the case that winch will be as good as new and with any luck we'll be able to try it out this weekend.
Cam
Pics to come later today.Could a machinist turn those Poly rollers down so they would fit, or would that weaken them??
I'm coming into this a little late and hope no one thinks I'm trying to hijack this thread. I learned a lot reading this, but need some help/advice. I'm also rebuilding my stock winch (yet to get the point of buying synthetic rope) and can't find a source for all the rubber seals. I searched for many hours on this site - no luck Mine got damaged in the tear down. Do they come as a kit? Anyone know of a source in North America?
. Shoot me pm and i will get them for you.
Is it possibly you jostled the tranny cooler lines when you were messing around down there last time?
This time, since I had already had an issue with it, I played it the smart way - removed the bumper, removed the winch, set it on my bench in the shop... put the bumper back on. Then ordered all new winch seals from Akella
