Done. Set of Pleiades ordered. After installing them and new rear springs I expect AHC to work for a while. I did replace fluid yesterday and measured L to H difference around 6-7 marks
PS: WHen talking about sensors -- They are among the weak parts of the AHC, both because of possible ingress of water/salt and because they wear out, so it's good to have a spare one. The Dorman replacement is not expensive (it's mentioned in a thread in here).
Replaced springs and globes. Rear pressure dropped by 0.3 Not much but better. I wonder why they didn't come to norm though. I installed "stronger" LC springs
I don't think Toyota AHC springs are different from Lexus AHC springs. 6.4 MPa is within spec. Rear pressures are 5.6-6.7 spec. Do you have anything beyond stock in the rear weighing you down?
This, pairing the 30mm spacers and new ahc coils is probably the best you can do for the health of your system with no extra weight.Throw coil spacers in the rear. You will retain the spring rate and increase the preload, reducing AHC pressure
Depends. The missing factor here is the vehicle height, front and rear..... My front pressures are too low, and my rear pressures are low.
Q1 - The best way to sort out front pressures is via torsion bar indexing?
Q2 - Is 4.8 Mpa for the rears ok (considering the heavier-duty springs)?
And, are these values representative of an average between several tests going from Lo to N?
You can make TS work on Win11. (But the perfect solution is to find a discarded/free laptop with XP or Win7)Do we need the program to see pressures? Is there a physical tool I can use instead? I don't believe Techstream is available on Windows 11.
My screenshot above was from a Dell Latitude 8th Gen Core i5 with W11 Pro. This page will help:Techstream is available on Windows 11.
forum.ih8mud.com
Just last week I tried out an OBD2 scanner and app that worked. The scanner is this one: https://www.amazon.com/dp/B076XVQMVS?tag=ihco-20Do we need the program to see pressures? Is there a physical tool I can use instead? I don't believe Techstream is available on Windows 11.
