Since horns are meant to get people's attention and avert danger I figure the sound should match the vehicle and these do just that. I may be over-thinking it but oh-well...
By the way TX, your rig looks awesome.... thinking about going from 33x12.50's to 33x10.50's myself...
Just knocked this out - thanks for the great write up - 20min tops... well worth the effort!
What do these aftermarket horns sound like? Beep? Toot? Meep? Mowooga? Help...![]()
Alright gents.
Swapped out my stock horns today for a new Hella horn set. Hella set looks pretty high speed next to the stock '86 set. Hella came with a switch, or relay of some sort, which I did not install. Just hooked up directly into the existing wiring. Works fine.
So my question is....will having not installed this relay-whats-it have an adverse effects?
Rob how did you wire these? Did you cut the plugs off?i did the hella supertones on both my 60's - great upgrade. GET THE F OUTTA MY WAY!!
rob
Did you wire the Hellas this same way? With the stock wiring. Or did you wire in the relay from the Hella kit?i did the hella supertones on both my 60's - great upgrade. GET THE F OUTTA MY WAY!!
rob
