Build Adventure Cruiser "Rosey" - How Many More Times...
Move the mounts have you fully welded everything?
Yea those mounts are fully welded, I was using a real s***ty MiG welder previously to tack and then I hired someone come weld fully. The tacks kept failing and I needed to set the pinion so I just (wrongfully) went for it.
Your pinion angle will change also never fully weld anything until it has been mocked up with the weight on it and double check all angles and measurements
What brand wire feeder do you have? Also you are looking for penetration. Select a high setting. On my Lincoln I run E @4-5 speed setting. When your welding it should sound like cooking bacon.
Would you go wire feeding over a stick welder for this use? The goal would be something I can weld up bumpers and sliders with in the future.
I stick weld at work on well casing all the time. Stick welding has more slag as pieces shoot off everywhere. Wire feeding is your friend. Stick takes time to master and depending on the rod size and heat you could burn through just about anything, frame included.
I have used a klutch welder from northern tools my buddy has one they are not to expensive i have used all kinds of welders for the price it not a bad welder
Here’s my mount for the hydro assist. That mount was shorter on the inside. Added a plate and welded to the mount. Shaped and welded to the axle.
