I have been researching how to adjust the timing. I think I got it down except how to do the jumper wire. Where do you put the wire?
I was going to use a paper clip. Would that be fine?
was curious if there was any negative side effects to increasing/changing the timing (advancing) on our trucks? Was considering running a smaller pulley on my SC and adding methanol injection eventually, as well as increasing the timing BUT I really don't want to stress the engine or lower it's life expectancy.
...UNLESS you decked the head and block which raises your compression.
old link i found laying around...
http://www.lcool.org/technical/80_series/timing.html
need to get these damn things organized...
bf
I lowered mine to pass smog and then lowered it again positing that it was contributing to my over heating issue(s). I'm currently at 3º
one question? when adjusting the timing on these truck advance a bit does one need to redo any of the other settings? ie: idle, etc?
