ADJUSTING TIMING
So, can We figure out a way to read the signal from the knock sensors so we can tell when we have advanced the timing too far ? Must be a way to do this! It ain't like an old Chevy small block where you could just keep turning the dizzy till it would not start..........
I've heard don't increase the timing over OEM specs with an SC. Be careful and hopefully an expert will chime in.
I'm not an expert, but you gain HP with timing. From a 30,000 foot approach, when you Tune LS engines, you get Air/Fuel correct (MAF) then work on advancing timing until you get knock. Pull off a few * in those specific areas and set it. Understand this is done on a dyno with Wide Band o2 and we can actually see when it knocks.
First point - with tuning 2 things kill engines.. Running higher RPM than the engine is made to handle and KNOCK..
Second Point - Some knock you can hear and some you cant.
I get it - My truck is a pig as well... its slow and I'd love to pick up some free HP.. One thing Ive learned is nothing in life is free. To those guy's and gals who have successfully advanced timing I say that's great. 18 year old knock sensors on these trucks "ain't all that" and no knock sensor and ECU timing retard guarantees you wont harm your engine.
My advice is spend your time and hard earned cash getting your truck in perfect running condition. I'm not knocking those who want to do this, just saying there are no guarantees.
Best to all,
J
I've paid close attention to the scangauge, and it doesn't *appear* to be pulling any timing. Do you think the knock experienced would be too much for the engine? The knock sensor should pick up anything large enough to hurt pistons right?
Scan gauge is the computer adjusted timing and the smog guy does not go by that. They only use the timing light and follow the instruction under the hood so I would dial it down to 3 before the test.
Yup. Adjusted timing to 3* and took it to the smog dude. Passed no problemo.
I'm pretty sure he didn't even bother to check the timing, because it isn't on the report and usually is. I know he didn't do the gas cap pressure thingie and should have.
I should complain.
:lol:
Then I came home and put it back to 6*.
Yup! That's how we do it! :)
Since I'm running premium I'm at 10. I'll give it a bit more time but so far not feeling a whole lot gain compared to regular and 7ish so might go back to that one day. From 3 to 6-7 was immediately noticeable.
Same here Qball. I agree that the gains beyond that are negligible. Im sure Mr T set it at 3 degrees to compensate for crap gas these trucks could encounter, but here in the US we can reasonably control the fuel quality so I'm pretty comfortable at 7 degrees advanced.
Right. I don't really have any numbers either. But the seat of the pants effect was very noticeable. And with my 2F, same thing: it liked about 10* rather than 7*
I had an immediate mileage boost at first, 1, 2 mpg but spent the next couple tanks wheeling, so shot that all to hell.
:lol:
Tough to get consistent apples-to-apples comparisons in the real world.
:lol:
Anyway...
And then the summer fuel formulations will come online soon.
:bang:
Mine will knock like crazy (ping/pre-detonation/whatever) w/out the timing being lowered/altered. Not sure why the knock sensor(s) don't kick the timing down like it's supposed to.
Quick update after going through couple tanks of premium gas. The ecu seems to be fully adjusted by now, out of gear idle was higher at 680ish and has since come back down to 650 like before but in gear idle still staying around 620 and it was was 600 flat before.
Here is the interesting part: I do think there is noticeable power gain after going to premium and advance timing to 10 degrees. It seems to have more pep and more torque, gear shifts seems to be a bit later on the hills but most noticeable improvement is that the engine is a lot more eager to rev and when it does rev there seems to be less strain.
I had my emissions tested a couple months ago. I completely forgot to reset the timing back to 3. I am running 7.
I passed.
I don't think they check base timing in CO. I didn't see them do it.
I did put in a bottle of Lucas Injector Cleaner per @pmccumber. He said this helps the NoX I believe.
It was quite scary seeing my rig lurching around on the 4WD rollers without any tether that I could see. I moved toward the back of the building...
