Adjustable caster front leading arm
incredible work .. will buy it and let in my living room .. those bolts are enought secure to hold the axle in proper caster position . ?
Thanks everyone, very much.
Bill
If you cant remember when Bill's truck was mobile you haven't been here long enough.
Bill,
have you thought about wristing one side of the arms to increase articulation ?, ( Think early bronco arms ) I know that you use (Now that was funny) this for expedition travel but wonder if you have played with that idea as well.
Dave
Well there goes the secret of going for the low mileage record.
Bill,
Dave
Yes I did think about it. Thanks for the reminder. At the time I had dreamed up a screwy joint design for the rear control arm that "might" relieve some pressure on the bushings; but it seemed the consensus was the rear was fine so I dropped that idea and any thoughts of trying to work a joint in to the front arm.
The only Bronco ones I saw used a bolt and a pin and I never liked the idea of a road rig with a pin. I always felt it would wear pretty quick. :confused: Two shoulder bolts, a bearing and a bushing might be good but would take more time to undo for off road. Of course I know very little about suspension design so this might not be what you were talking about.
Bill
