Adjustable caster front leading arm
I came up with this idea several years ago and have slooowly over the years designed it and started to machine it. It is just a concept and I may never finish it so for correction I would recommend plates from Christo Slee or Landtank.
This design allows for 23 degrees caster total adjustment. 5 degrees for the low riders and 18 degrees for lifted cruisers. That is from zero; not from the Toyota specs. As far as I can tell in the stock position it is about 1 5/8 inches lower than the stock arm. I did not machine the rear portion of the arm yet although I have made the drawing and coded it. I apologize for posting it in this condition since much of it will probably be hard to figure out.
Disclaimer: I have no idea if this will work or not.
Bill
More pictures.
Last picture.
That's insane.
-Spike
I have not a clue what I am looking at...but is sure is pretty looking. The camera angles don't do it for me.
You sir have some skill with the machining!
Thank you. Maybe another picture will help. Keep in mind this is just the front half.
The second picture shows the start of the bottom where I welded the curved gauge part to. It is 1/2" plate and is the part that would be slid on. I drilled and tapped a couple of holes at an angle for jack bolts. These would just be used to adjust the center section (axle) for caster alignment, then removed. This is also the part that would be slid on. As I mentioned it is about 1 5/8 inches lower than stock.
For what its worth, the passenger side would be very different. It does not need a gauge, and would be much shorter for clearance. Another reason this one sticks so far forward is I wanted to be able to have the lock bolts on either side of the arm and to make the arm adjustable (alignment) without removing anything. The bolts in the center would not be accessible and do not tighten. I put them there to help to help keep the arm from spreading from twisting.
Bill
To much bling to be on a cruiser. :pJK, That is one work of art. Very nice work!
That could be looked at as a work of art!! How much does it weigh?
beaker appear to be prop that = aprox thickness of that beutifully machined creation - I'm surprised you didn't make an ellagant stand instead of using the ckt breaker:flipoff2: - very cool.
the only sad thing about all this is that i believe Bill's truck hasn't moved since i have been a member of Mud. He keeps adding all these projects, like dual snorkels, alternator brackets and now some crazy caster time machine!! :)
