I just received front and rear adj tracks bars from Dobonison's. I was just wondering if anyone had a rough measurement to get me started. I am running the 3.5 tapered setup. Tried to google measurements, but nothing to help me out.
Depends on the goal. If it's cosmetic, adjust so the tires are the same distance from the flair, on relatively level ground, a weighted string, plumb bob helps. If the goal is maximum stuff, wheel travel, adjust to be even at full flex, in this case the length will be very close to stock.
Isn’t tracking the front and back for drivability on the road?
Both panhards are opposite of each other so if you achieve stock location the front axle will be on the right more and the rear will be driving on the left. You will get uneven wear on the tires and the alignment of the car will be off.
Well, there’s not. Think about it.If your tires are placed:
And your vehicle wants to drive straight, to me there is a problem.
Nope. Had a 4" lift with OEM panhards for years on 2 different 80s, both daily drivers. It is a cosmetic issue and does not effect on road manners or tire wear.If your tires are placed:
Do what you feel you need to do. From experience, I can tell you that with 5” plus lift and 37’s, mine handles much better now that I have my axle centered and I built a bracket to raise my rear track bar 4”.Alright, all the above makes sense and is logical. But now I question my very limited understating. If it is cosmetic, then what would be the advantage of adjusting them besides astethics? I thougt that I have read that rear pan hard adjustment, bracket or rod, stops the truck from being darty on the road.
