Adding oil light sender/switch to 3B Block
GS 60
Ireland
Hi
i want to add a oil light sender/switch to my 84 BJ42 to feed Watchdog TM unit? Are there any spare ports on block to add sender?
Is adding a sender the best way or only way of doing this?
Thank you
There is an oil galley that runs along the right side of the engine. You should already have 2 sensors in the galley (oil pressure gauge sender, and oil pressure sensor for EDIC). There should be one more plug in the galley that you can pull out to install your aftermarket sender. Or, you can tee into one of the aforementioned spots.
Thanks to you both for responses?
Basically, I am going to fit a Watchdog TMI which i have had lying about for years, as Splangy said, the TMI is primarily for water temp, but it has a low oil pressure function as well which I was thinking of hooking up.
Here is the link to the TM1:
ENGINE WATCHDOG TM2, Engine Overheating Alarm, Gauge & Sensor
You will note from link that low oil function will not work off oil gauge sender, which I have in the 42, it requires an oil light sender/switch to be installed for the TM1 oil pressure function.
This is why I was contemplating fitting an oil light sender as per instructions in Watchdog instructions.
I don't particularly want or need an oil light on the dash, its just to facilitate the TM1 oil pressure function as per instructions?
Could I take the the TMI wire directly to the EDIC sender ?
