Adding CDL switch - placement question
Flank
American by Birth, Texan by the grace of God.
Flower Mound, TX
Website
www.staltimber.com
I've read all the bit on how easy it is to get the CDL switch hooked up, I just received my Ebay'd switch, Shipped from friggin' MONGOLIA of all places! :eek: Apparently, I could not find one used in the states... Actually, it is a hazard switch, have printed out NLX's relabeling template :clap:
Placement / wiring question before I break into my dash:
In the most common placement location of the CDL on my, left of the antenna switch, I have the factory security system light and glass break sensor. Does anyone know if there is enough slack to run the CDL harness down to the lower switch blanks by the defroster so I do not have to disturb my security system? If not, should there be enough slack in the security system wiring? Anything I should be on the look out for, like if I clip some wires I will have trouble?
Thanks in advance. I am not scared of grease or wrenches or the like, but I am not a fan of electrical work. I'd rather open up a diff than the dash. This is my DD, so I don't have time for it to sit taken apart for a day or two, and my :princess: will surely take my head off if I can't get the kids to school.
yo! do not cut anything! there's not enough slack to run the cdl down low; you have to keep it in the top row.
instead, move your antenna up/down switch all the way to the bottom, next to the stock heater switch. there's plenty to relo it there. (just be sure you run the wires correctly behind the bar beneath the AC controls; or else you'll pinch your antenna wires when you put the dash back.)
my top row is: security (right where it was) › CDL › hazard › defroster
took me about 30 min to move things around. but it was all plug n play.
edit: careful of your dash to the left of where you're working. when you pull this stuff out, the AC controls/trim pieces invariably push/rub on that area and can scratch it if you're not aware. tape it up to avoid scrapes, if she who shall not be angered is at all anal about that.
Have you thought about getting another used pigtail connector and then just making yourself a new extended pigtail? Then you can put it wherever you want.
BTW, glad the lables worked out :D
I used the lower right slot for mine :)
The factory harness wasn't long enough, but extending a few wires that are color coded took just a few minutes :cool:
https://forum.ih8mud.com/80-series-tech/189314-part-number-cdl-switch.html
After looking at it, I think I would really rather the defroster switch be by the rear heater switch, and use that upper slot for the diff lock. Anyone see any issues with that?
like this:
You shouldn't have any issues no matter where you put it, but I prefer the lower right as it's just a finger flick away from the shifter :)
x2 - Put it where somewhere you will remember to hit it. LOL, I laughed the first time I read some say "I forgot to engage it because I installed the switch"............. well I have done it too now.
I can 100% attest to doing JUST that :doh:
I bet you can, scary and educational write up... "Truck can be replaced, we have life insurance on you, Just as long as the kid is okay!" If I remember correctly.
Not planning on the Pin 7 mod yet, really have no reason for it at this time. Makes sense to me to have the climate control (heater and defroster) in the same place, and to have the CDL up high. I plan to do it this weekend.
Did switch relabel last night.
Job done! :bounce:
Seriously, that is about the easiest damn thing I have ever done, less than ten minutes, start to finish.
The switch ended up in the top left slot, where the alarm was, it did not have enough slack to go below, and I did not feel like splicing. The defrost switch might have had enough room to go below, did not feel like messing with it.
The factory Alarm indicator DID have more than enough slack, and it transferred to the bottom row... for now. Not as visible, and may make the move to the left of the steering wheel eventually.
:grinpimp:I spent more time playing with the CDL, marveling at the magic of the ABS and Diff Lock lights coming on on the dash than the install probably took.
:doh:I did, however, do a crap job on the label. Oh, it looks decent enough, but I did not color in the black areas enough to black it out, and the whole label lights up... Sorry to do your mod half ass, NLX.
tisk tisk :D
The thickness of the paper you use also makes a difference I've found.
Just thought I would throw out that I was able to put my CDL in the position of the old security indicator and I had more than enough slack to move the security indicator down to the empty slot just left of the rear heater switch on the LX450. Doubt that thing even works but I didn't feel like tossing it out and if it does work then great.
You did not look hard enough in the For Sale section: https://forum.ih8mud.com/sale-parts/295911-80-series-miscellaneous-dash-switches-pigtails.html
Make sure that switch is not made in China::grinpimp:
I know you are done but figured I'd chime in on where I put mine...
Top row is: CDL | OEM Security Dealyo | Rear defrost | Hazard
Bottom row is: Blank (some day subtank switch) | Rear Heater | Antenna
I elected to relocate the antenna switch down because I almost never use it so it is out of the way.
perhaps now, but there was a lot of chatter back then about using hazard switches instead of diff lock, and there must have been a run on them, I could not find any. Anyhoo.... The switch was OEM, and it has worked perfectly since installing back then. I have relabeled it with a better print to make it less opaque, it was driving me nutz at night. All good now.
