Thanks. I’d have it professionally installed but am looking for… should I or not?Measure 10x and then cut. No, don’t cut yet….go back and measure 10 more times. Then go to sleep and wake up and measure 10 more times.
forum.ih8mud.com
Obligatory photo from a previous adventure with @1world1loveIf you go anywhere with @TLC2013 you probably want a snorkel![]()
Hi folks,
I’d like any and all input on adding a snorkel to a Slee Built LC 200 Heritage ( Blizzard Pearl). Thanks!
ThanksIf your intended use of the vehicle would necessitate a snorkel then I'd say yes. There are a few who have hydrolocked their engines and I'd say that they would say yes, but lots of people get by just fine without one. I personally have driven in some pretty deep water without one, but I would be lying if I said that I was entirely comfortable doing it.
not reallyI look at it more of a need based decision. Do you need one?
Thanks for your inputI'm going to say the biggest arguments against a snorkel are it's going to kill your resale value (in my opinion, I don't have data to support that), and you probably don't need it. A white HE LC is a good rig to have, and the value is very solid. I would not want to make mine the 1 in a 1000 that has had a huge hole drilled in the side for a snorkel. However, if you drive in deep water then yeah, maybe it makes sense. Or if you just like the look. But since you asked, I'd say no, don't do it.
Fenders are surprisingly cheap. . .
I’m going to drive, enjoy, maintain, repeat, and plan on seeing how many hundreds of thousands of miles this thing holds up. Toyota reliability.I'm going to say the biggest arguments against a snorkel are it's going to kill your resale value (in my opinion, I don't have data to support that), and you probably don't need it. A white HE LC is a good rig to have, and the value is very solid. I would not want to make mine the 1 in a 1000 that has had a huge hole drilled in the side for a snorkel. However, if you drive in deep water then yeah, maybe it makes sense. Or if you just like the look. But since you asked, I'd say no, don't do it.
Agreed.It's cheaper than a motor
Having sold and installed hundreds of snorkels on a wide variety of Cruisers.... I can't say I've ever had a customer tell me they wished they would not have done so on an appropriate build. However I've had plenty add one after having to rebuild/replace a motor including the 3UR![]()
