I have to add to this that most of the complaints we have on the Linx system is from an installers point of view. We do tons of electrical installs and even though the functionality of the unit is great for the end user, what people are not going to like is that if they come up with new modules or a way to control different devices, then you have to take the inside of the truck apart again and run new wires. Thus more $'s for every install, which is great for us but not so great for the consumer. Also adding another cost of a relay bank in the engine bay in both material and labor costs is not ideal.
I just think that v2 could be so much better.
We will be doing one in out shop Tacoma and investigate how many of the leads we can pre-run to the engine bay to try an avoid the whole deal of running wires again. 2nd to that, I have always had a dislike for any harness that uses individual spades / connectors to connect each lead to a unit. Just like the 5 wires on the back of the ARB switches. If you ever have to remove the system, you are going to have to label each wire and take notes / photo's to ensure that it gets plugged in correctly. Not sure why the unit was not built with 4 or so Molex type connectors that a harness plugs in, so that there is no confusion when swapping out a unit that the new one is plugged in correctly.
What I do like is the ARB pressure transducers to allow you to air up or down to a specific pressure automatically if installed correctly with the proper plumbing to them.
As for Switch-Pro's app, yes there was some issues early on and there might still be. What is nice is that they listen and have added a ton of functionality in the newest generation and they always listen to input. Also what I do like is that the switch panel is always installed and pretty bomb proof, but you can get the phone app to have more functionality, that I am sure will grow over time.
