Accelerator Pump Boot
Castle Rock, CO
Please don’t bang me up if I didn’t post this in the proper place...I got banged up a bit over the Holidays... the 40 won’t start without adding gas to the carb its a 21100-61024 - the rubber boot is DERANGED and cracked. Is there a place to buy the rubber boot or assembly? Pic is attached (I will delete this post once someone guides me as I know pics are somewhat discouraged ;) Also, I don’t have my silver star anymore, so I can’t figure that out either how to support this site. Thanks and let’s hope for a better 2021.
Thank you! I did a complete overhaul 4 years ago, and only put about 5k on the engine...I am trying to get acclimated to the new site, as it’s been awhile (got the star...hahah) is there a local auto star that anyone recommends to pick up this stupid boot? SOR wants to charge 16 to ship it....yikes. Wife is pissed that the garage smells like gasoline as I drop about a pint on the floor.
You either have to pay large for the single boot or get a carb kit. These boots are very susceptible to ethanol fuels.
The plunger boot is part number 21699-60200. Can be purchased thru Toyota -> click here <-
Yep. I run non-ethanol gasoline whenever possible.
look at Mike's Carburetors. I got a boot from there that worked. No affiliation. I have gotten several different Carb parts, for various applications, over the years from them.
GA Architect got mine fixed proper. The Keyster boot from the rebuild kit rotted before I ever got the carb installed on the manifold. The one from Toyota worked, and still is working.
Maybe there is a trick or two to get it started? How are your spark plugs looking these days? Black and shiny, powdery black, or just tan on the white insulator?
My carb runs lean in winter cold (contrary to an expert), and I prevent a high-altitude hiccup by capping the vacuum barb on the power valve. Running headers.
Are you thinking the black accordion boot is causing the no start?
I would guess something is plugged or the AP plunger is shot. I believe Mike's plungers are leather and might be better for ethanol. After you add fuel by hand, does the rig run good?
car runs great....I just have to put gas in the carb. The boot is torn to shreds. It’s been a while since I’ve been on this site...Not sure who Mike is. I do recall Jim helped me out a bunch years ago. Thanks! Leather would be better. Can you please send me his info?
Mike?? Reread post 10.
Plugs are clean - she doesn’t run too rich. Accelerator Pump looks like me after New Years.
"I would guess something is plugged or the AP plunger is shot. I believe Mike's plungers are leather and might be better for ethanol. After you add fuel by hand, does the rig run good?” - Who is Mike with the leather plungers? Happy New Year! --- EDIT - Mikes Plungers - I was looking for a handle with Mike in it. Sorry
Perhaps you've done this—> Crank engine to prime the carb, shine flashlight down primary side of carb, pump accelerator linkage by hand and watch for a good fuel squirt.
Another thing to check—> does your choke plate actually fully close
hi Joe ,
happy new year ,
my name is Matt , and i would like to Kick Down , some Karma for your cause .........
- to be clear there is No cost involved , i will also take care of the shipping too , this is what some of us call MUD-SHIP
- i agree with most of the above and have my own 2 cents to add , some of what you describe has the symptoms in my experience of a BAD fuel cut solenoid , so i am including one , a fresh crush ring , and most important it's tiny tiny microscopic O-ring on the tip , you MUST apply a tad bit of petroleum jelly or di-electric grease so it does not tear when being installed , take note if you old fuel cut , has a o-ring still on the tip upon extraction
from the air horn or not , and report back here in the PM , im curious about this fact .........
- next up is a OEM TOYOTA Plunger Boot , simply put OEM Toyota parts are the best you can source , hands down .....
- the Plunger is the leather type out of a older NOS Keyster JAPAN kit in my stash , no better part for your fix job ahead
- im also prescribing you update your fuel filter to the most up to date refined Carburetor filter Toyota has ever made in my opinion for a Carburetor equipped Engine , the 23300-38010 is made out of a translucent plastic and you can see if a outside culprit such as dirty gas or the like is possible cause here or if Rule it out and keep your Focus Points from the filter forward .........
it has the most filter media of all the FJ40 / FJ60 F and 2F engine Fuel filters and catches everything in my opinion , and seeing or not seeing whats what is a big diagnosis tool in your box most folks overlook ...........perhaps
please PM me your shipping Addy info , i will have all what you see on my messy desk , in Mondays mail to Ya ...........
its a new year , and My KARMA bank is empty once again , time to start filling it up and what better time then now in a area if mechanical focus points i am very familiar with ..........
you have a EXCELLENT crew of fellow members here helping you and sharing there input , take note there some of the best here on the FORUM
, PM me and lets get your Rig back to where she belongs , :cool:
it's 2021 OMG ................ 🤔
matt
Thanks Matt! That’s very generous of you and I appreciate it. I will pay it forward for sure. 2021 is looking better than last year. What a way to wake up this morning. Sent you a DM.
-Joe
