ABS System delete
I did the abs/LSPV delete, pretty much replaced all of the hard lines, and put in new slee braided lines. Also all new calipers.
When I went to pressure bleed the system, I'm getting nothing out of the rear brakes. I cracked the master cylinder fittings to bleed them and got some air out. Still nothing to the rear brakes? Wtf? I cracked the first tee (where LSPV was) and getting nothing out of there. What am I missing?
I wish you luck!
I'm 5 days into this job and my brakes are still worse than before, scary even, the truck can't be driven safely.
My truck was driving and stopping a week ago, I drove it from Vancouver to Pheonix to visit a friend on the way to Baja, I just didn't like the brakes. Now I've deleted the ABS and LSPV, replaced a front caliper, vacuum bled the system 7 times, using over 3 quarts of fluid.
I just walked to O'Rileys to see if they can get me a new Master cylinder, they have to make some calls. So fun.
I would see if Cruiser outfitters could over night you one before putting in big box store crap 🤷‍♂️
Obviously you’re not going to get one today 😉
Thanks, I just ordered one from Napa, it's only a 2.4 mile walk. Hopefully I get it tomorrow and it solves my brake issues.
Good luck
I'm 6 days and over $500 into this two hour, free job and my brakes are still worse than before after 7 vacuum bleeds.
New master cylinder, new front right caliper, new bleed screws, 4 quarts of fluid, plus a Willwood adjustable proportioning valve.
No pulling left or right, just no power in the brakes, they bite then fade and pressing harder didn't make much difference.
If anyone has any thoughts or advice I would really appreciate it.
I would say it’s the booster it’s really common that they go out.
These trucks are now 30 + years old.
Thanks, I guess I'll just keep spending money until my brakes work properly.
Did this job 2 weeks ago and scratched my head for 2 hours thinking i messed something up because the rears would not bleed when i loosened the bleeder valve. Ended up finding that both of my rear caliper bleeder valve/screws were rusted. If you still can't bleed the rear or are having issues recommend removing the bleeder screw entirely and inspecting to make sure the tiny hole on the inside isn't rusted shut. Must have been water contaminated old brake fluid that caused it. I'll probably replace the screws next time i go to bleed the system but for now I just went at them with a wire brush, spray cleaner and a paper clip to clear the crud out of the passageway then everything worked well. Definitely noticed an improvement with the braking performance and "grab" but the pedal feel is still less than desirable. My next move will be to replace the booster with a Seiken is what it's called, i think. Previous ownership decided it was a good idea to slap a Cardone reman one on there. Additionally, on inspection of my abs module after removal, I contribute the lack of brake fluid maintenance as the reason it failed, and I had the abs light. It was all rusted up too inside.
Post 65 states he replaced the bleeder screws and went through 4 quarts of breaks fluid.
Always happy to help a fellow Mud member spend his money 😉
When I did my delete I put in a new booster at the same time and all was good 🤷‍♂️
Honestly, just trying to help !
Before you start your vehicle pump the brakes 7-10 times on you last pump hold the brakes down hard. Start the vehicle while still holding the brake if the pedal drops or starts to feel softer your booster is likely good, if it stays hard ( no change in pedal feel ) your booster is bad.
Thanks for your suggestions, I'll keep working on it.
Yes, I replaced the bleeder screws and the rears seem to bleed fine.
I'm going to test my new caliper and vacuum next.
If you need a brake booster, I have a low mileage one that I'd sell. I took it out recently when I installed my Torfab/Honda iBooster. I had replaced it less than 500 miles ago due to failure of the diaphragm on the original part. Drop me a line if you're interested.
