ABS Delete and Part time
N. West CT.
So I recently converted my 96 80 to part time with a Lokka locker. Part time was a pretty easy install but I did research a bit before tackling the project.
Today I almost finished off the conversion by deleting my ABS unit and LSVP valve. Almost because I ordered the wrong proportioning valve. I ordered a bubble valve m10 instead on regular flare. Aw well. I just put in a coupler in place of the prop. valve until I receive the correct one. So until then the brakes will be a 50/50.
I show in the pics the main tools for the job...., Well at least on a New England 80. Vice grips are the key tool. Frozen bleeder valves on the rear cylinders thanks to rust. That along with some MAP gas.
I tested my master cylinder while doing to the conversion also. I blocked off both ports and tested the pedal with the truck on and off. The pedal was nice and stiff. So I suspect the OEM Aisin that is existing is in good shape.
I did notice a loose rear pass caliper while doing the job. The caliper itself was tight but the self adjusting cage of the caliper was loose. The other side was tight. Thinking that caliper is not functioning properly.
Big thanks to Jcardona for the pics with detailed diagrams. Sometimes I feel like I'm cheating with all the help here on Mud!
I didn't take it for a ride but I did a quick test in the garage. The pedal felt nice and stiff but felt like the rears where working to much as expected. I will order the correct Prop. valve and install early this week.
Part time Locker is a Lokka at Lokka.com in Austrailia. With a tall lift and 37's it did help with driving and drivetrain vibes.
I believe our lines are bubble flare, I think you got the right valve.
our lines are standard inverted flare. I just researched and Wilwood doesn't make the regular flare so I will have to convert those two connections to bubble flare. Might be able to get it done today in the mist of other things to do.
Did the ABS delete on my 93. you don't need the portioning valve. Try it out before you order the right one.
Interesting.... I would think this would result in the rears locking up. Every time I adjusted the LSVP and It was too much rear it would lock them up in the snow/wet conditions.
I have been running without for a couple years with excellent results. After a couple full lock ups (dry pavement) Im convinced no rear portioning is needed.
I have been running without for a couple years with excellent results. After a couple full lock ups (dry pavement) I'm convinced no rear portioning is needed.
Thanks Phil. I will test today. Never drove it last night when I was done. BUT when I used to fool around with the LSVP and put more brake force to the rear it would make the brake pedal feel much harder BUT it would have much less braking force.....????
I also found my rear pass caliper is very loose on the cage part. Guessing it needs to be cleaned or replaced. The aftermarket calipers just don't hold up to New England mud, salt, etc. The rear calipers take a beating in the mud. The other side froze up a few months ago but I was able to revive it for now. It was completely packed with mud.
YMMV:meh:
What did you use for a flaring tool?
I didn't use a flaring tool. I bought 2 pre made lines for the two I needed. If i add the prop. valve I purchased I will have to use a bubble flare going into and out of prop. valve.
Any insight on why the pedal would get harder but less braking power if I apply more force to the rear?? The LAST thing in the system that is still original is the booster...
The booster fails one test. When I hold pedal down while truck off then start truck the pedal goes far down. The FSM says it should move "slightly"....
Yes, they are from Jcardona. If you search you will find his thread on deleting LSVP.
I've found that hard pedals usually means stuck calipers. And I use Napa eclipse calipers all the time with good results.
Right on Rick. I ordered one new rear caliper today. Seemed very loose on the cage so I am thinking its prob hung up. I didnt order napa but some other aftermarket. It seems the rear calipers really take a beating in the elements.
The pedal feels even better but when I first drive its very stiff with not much action. As I drive more they start to grab more. I am wondering if the rotors on the truck are garbage and dont bite well. They where brand new when I bought the rig 4 yrs ago and brand un known. I really dont want to keep throwing parts at it. I've never had such a hard time getting solid brakes in a vehicle before. What a drag. I have been driving it like this for yrs so its not terrible I just know its not what it should be.
Well I decided to go for a drive with my son this afternoon to feel out the brakes more. They started to grab suprisingly well after some road time. My thought is maybe the rears where not really working to well and maybe a few hard stops with the setting at 50/50 freed them up a bit....??IDK.
I've had issues with the rear calipers a few times after excessive mud wheeling. Maybe I will toss in two new rear calipers and see what happens. They both have been beaten back into working order a few times after frozen pistons/pistons filled with mud. I usually free them up with WD40, compressed air, and heavy c clamp work.
Just an update for the thread. I replaced rear driv. calipers thats been sticking for awhile as well as the abs, lsvp delete
MY BRAKES ARE AMAZING!!!!!!!!!!!!!!!!!!!!!!! Who knows what the culprit was but either abs unit or lsvp. The lsvp was new 20k miles ago.
Anyways this is a must for someone who is already part time.
OR I bet just ditching the lsvp would make a huge difference.
Where did you get the detailed description photos that you show on this thread? (photos of parts with lines explained and colored?) I have searched my a## off here on Mud and cannot find them.... can you please provide a link?
cheers from one that is about to DELETE THE F"#$"#% ABS CR"#$P :) (did I mention that i hate ABS?)
