ABS Actuator failure?
Groveland MA
Website
landtankproducts.com
I'm down in Asheville NC and my truck lost it's brakes at around 5700 ft.
Originally I thought it was the MC that I got from Napa a few weeks ago. But another one proved that wasn't the case.
I beleive it's the ABS actuator.
With my son pressing on the brake pedal I get pressure on the inlet of the ABS, confirmed by a spray of fluid when I crack open the line. However with my son holding the brakes on I can loosen both output lines to the front calipers at the ABS actuator and get no fluid to pass.
I've got my FSM here and will dive into it but was hoping someone can confirm that fluid should pass.
I can't imagine it not being it but I really have no idea how they are built.
Rick--
Considering that the ABS acutuator is right after the MC and all of the brake lines run from it to the calipers, I wouldn't discount something going on with the actuator.
IIRC, the FSM has diagnosis for ABS actuator issues having to do with certain electrical connectors, though I don't have it in front of me to take a look.
Other than that, I don't know what to tell ya man. The ABS actuator is a very "murky" assy. for Toyota. I've been searching the net for a long time to see if there was any technical data regarding it, but I haven't found anything substantive and the FSM is very thin on detail.
That said, I do have a good one that I can ship out to you tomorrow if you need one. Let me know. New ones from Toyota cost upwards of $1200, IIRC.
-onur
Since fluid has no problem passing under any other circumstances i.e. bleeding brakes without engine running. Your conclusion seems pretty logical to me as well. I actually assisted the bleeding of my brakes with a vacuum bleeder by pressing on the brakes last weekend.
Good luck and let us know what you ultimately find.
Thanks for the offer Beno.
right now I've located 5 through car-part.com within 70 miles. They all want $100.00 for them. Right now I only have rear brakes and if you look at how the plumbing is the rear is plumbed in parallel to the actuator while the fronts are in series. Hopefully one of these units will solve the problem.
Sorry to kinda hi-jack here, but I think it relates.
I've got the mushy-brake syndrome that's been talked about a bunch around here and after reading all the threads about it, I'm starting to believe my issue is the ABS actuator--though I can't confirm that yet...
So, I saw this asked before, but I didn't really see an answer for it: What about bypassing the ABS actuator and pulling/bypassing all the ABS stuff? Anyone done this or have any ideas on it?
-Ferg-
Beno did that, but it will bea little while before he can report on how his brakes work sans the ABS. Other than that , I don't know of anyone who DX'ed the ABS.
ugh rick. sorry. that is some hilly country down there. i was just there on our drive to austin. gorgeous. do let us know how the actuator works out. i have a used one coming from cruiserparts this week. i am hoping it is the magic bullet i have been looking for.
be safe!
I've been running without ABS for about two years now. The sensors are still in place but the wires are clipped and have been removed from their routings back up to the ECU.
I recently did take the ABS actuator out of the engine bay. All of the brake lines leave the MC and go into the ABS actuator and then go from there to their relative calipers. When the rig is up and running here pretty soon, it will be the first time for me running the truck with the brake lines straight from the MC to the respective calipers. This will also be the first time bleeding the brakes without a ABS actuator for them to go through. I am hoping that this will actually make the brake bleeding process easier and less troublesome in the long run.
I'll report back once the truck is up and running.
-onur
not that it really relates to this thread, but i also was running without ABS for months. It was due to my skillz at cutting siezed bolts out of the swaybar and also carefully missing yet cutting the ABS wire in half. I felt no real threat at running around without the ABS until it rained or we got some frozen stuff. At that point, i realized that ABS was important and spliced the wires back together.
I guess the point is for you southwest folk, ABS isn't that big of an issue. But for those MASSholes, i'm sure it is!! :)
Someone posted recently about how he fixed his mushy brakes by replacing the actuator. FWIW.
I'm at a local guys house and the actuator did not fix the problem as well as te ABS controller. My problem is that I has no front brakes at all. I did have pressure on the inlet to the actuator but nothing flowing out. Right now the truck is at the dealer as I'm clueless to what the problem is and I still have a 15 hour drive home.
One thing I did find was a bad ground for the circuit. I was measuring only 10.0v dc between power and ground on the actuator plug.
Whew...if you are clueless I dont know how much I would bet on the Toyota dealer!
I'm now at a hotel and I did talk with the tech as he saw a lot of fluid all around and I explained that I had done a few things and he's now going to run some diagnostics.
He should be able to track down the problem with the specialty tools the dealers has over a guy with a 65 piece Craftsman tool kit and a 14 YO pressing the brake pedal.
Rick,
I just want to understand correctly, You have rear brakes, not just the cable e brake? This is really strange.
If you lock the center diff, does the front brake situation change? Idea being that the ABS ecu is shut off.
The fact that you have rear brakes vs front sounds more like the ABS ecu is seeing a false slip situation. And the fact you have replaced the actuator and MC.
What was happening when did the fronts failed?
yes rear brakes only.
I was driving down hill with the center locked, ABS off, and one push was fine and the next one went to the floor. No fluid loss and no pressure at the front calipers.
I got off the hill in low range and first gear.
If you look how the rear is plumbed you'll see that the actuator is in parallel to the rear brakes while the front is in series.
The rear line from the MC runs down to a "T". One side of that "T" goes back to the LSPV the other side goes to the actuator input and then the output runs back to the LSPV. Those are the two lines going into the LSPV. So even if there is a blockage in the actuator there would be pressure to the rear from that first line that runs straight back the to LSPV from the "T".
The actuator looked like it has three solenoids and it seems like it's always in a active situation preventing slip but instead of pulsing it's always on. The thing is that I can get the ABS to activate under hard braking even though I know it's not slipping and there is no codes for the system. I did unplug the actuator and it didn't make a difference but did light the ABS light.
Sorry man I am out of ideas.
I am a bit shocked that the failure situation, nice driving and quick thinking.
I assume you were checked the abs wiring harness for shorts when you found the bad ground.
Rick,
Sorry to hear about your troubles. That is the weirdest brake failure I ever heard of. I hope the dealer gets you back on the road soon. Oh, BTW, if you have AAA, I think they have some kind of insurance or something if your travel plans get screwed up due to mechanical problems.
