Rick - wondering if your first thought might have been correct.
From what the MC diagram shows, there appear to be at least two distinct circuits within the MC. The FSM actually refers to four hard lines, though the diagram seems to show only two--the point being that you may have a failed front circuit.
EDIT: just re-read your initial post...guess the MC is not the problem.
Is there any additional Toyota document available that describes the ABS system? This seems like a pretty glaring omission to an otherwise comprehensive FSM.
... (right-click, save).
I did unplug the actuator and it didn't make a difference but did light the ABS light.
According to the manual that I quoted above, unplugging the actuator (or removing the ABS fuse) puts the system into a fail-safe mode and you should have 4-wheel braking.
Have you looked at the lines going to the front calipers? I guess you would have mentioned any significant loss of brake fluid.
Keep us posted Rick!
-B-
I've had similar experiences... drive to work with no problem, then pull out of the parking lot to go home and the pedal hits the floor. It was an older vehicle converted to power brakes so I mistakenly focused on the booster and master cylinder (they came together.) This happened several times with a bleed restoring the pedal each time. Eventually I found a crack in the front rubber brake line and replaced the line to fix the problem.
Symptoms were the same... intermittent, NO SIGN OF FLUID LOSS (that baffled me... I ultimately presumed that it had a pinhole which didn't squirt on the vehicle and maybe sucked air while cooling???) Fronts not working, but rear brakes were (2 circuit system.)
Hope you have better luck diagnosing a very frustrating problem.
Just got home and glad to be here!
Wish you could have enjoyed the rest of cullowhee.
