I have been pondering this and have seen the threads suggesting it will probably bolt up but getting it electrically hooked up would be a nightmare.
The reason I'd like to do this is to have a lower 1st and a higher overdrive. Here are the ratios of the A343F and A750F:
A343F
2.80
1.531
1.0
0.75
NA
A750F
3.52
2.042
1.40
1.0
0.716
I think it would improve mileage and be a better off-roader.
My guess is it bolts up b/c the 2UZ-FE had both transmissions bolted up and the 1FZ-FE also bolts to the A343F. And I believe both the transmissions bolt up to the HF2A(V) transfer case.
As far as the transmission ECU, couldn't one covert it to be a manually-controlled automatic, or manumatic as this guy put it?
And before anyone says, "just drop the 2UZ-FE into your 80" or some variant of that, I don't want to do that. I like my 1FZ and I'm keeping it.
What do you guys think?
A343F
2.80
1.531
1.0
0.75
NA
A750F
3.52
2.042
1.40
1.0
0.716
. I don't think it damaged anything because everything works fine. I just started it back up while driving and kept going, albeit with shaky hands and an unhappy wife. Lucky I wasn't going around a corner and suddenly lost power steering. So I hear what you're saying.
