- Joined
- Sep 1, 2007
- Threads
- 34
- Messages
- 588
Anyone do or see an A750F swapped into a 80 series cruiser?
I am sure that I want to build up a transmission for use behind a turbo'd 1FZ-FE
Why not start with a A750 as a core and get a lower first gear, a taller overdrive, close ratios and a bonus gear between them? Build it up while waiting for the original trans to start slipping.
4 spd 2.95 first
5 spd 3.52 first
Would be like having 4.67 gears instead of 4.11s
Going from 31's to 35" tires a calculator says requires a "4.629" ratio... kind of about perfect reduction of first gear going to a A750.. I do think one should go with 4.56 gears and the A750F. But if you cant bankroll gears, lockers, and the trans all at once the lower first gear on its own is good to have. The 4.56 gears combined with the lower first would be like having 5.07s in first on a 4spd. But way up in 5th it would be like having a .656 over drive since the 4.56s were about .06 to 1 shy of matching the tires.
4th gear of 4spd 0.753
5th gear of 5spd 0.716
May or not be worth it for me to get this to read,
ToyotaS New Five-Speed Automatic Transmission A750e/A750f for Rwd Vehicles
4 spd 2.95 first
5 spd 3.52 first
