A quick question, hoping for a quick answer
Mound, MN
Picked my new toy up last week, Friday 1994 FZJ 80 w/ 159K. Had the coolent flushed and filled, lube, oil, and filter, air filter, break inspection, etc. before taking the truck home. I fully intend to work on this truck myself, and have schedualed a full fluid replacement in the next 30-45 days. So everything I could address right away has been done. So today, 2 hours before I'm leaving for our cabin for the weekend, it throws a code. There is NO difference in driving, engine idle, etc. I crawled under it and the o2 sensors look like they could be replaced, I've looked through all the records and I don't find when they have ever been replaced. I haven't bought a code reader yet, was waiting for the next paycheck, and there isn't an Auto Zone any where close to where I am. I really don't want to unload the truck and tell the kids we're staying home. The coolent levels are great, oil is fine, tranny fine, just the damn code. I re-set it and it stayed off for a good amount of time, but then flipped again with slow city driving after the truck had been running for a while.
Again, no noticable difference in engine performance, stutter, etc. So I'm leaning towards heading up north, approx 150 miles each way, and addressing this come Monday. Is there anything I should pay close attention to during the drive? I'm going to pick up a code reader on Monday and I'm all but certain I'll get the reading that the O2 sensors are the issue. I leave in 2 hours, so I'm hoping someone is hanging out here with my answer.
Thanks!!
Jay
If the check engine light starts blinking, you need to pull over. Other than that keep an eye on oil pressure and temp. That's about all you can do until you pull the code.
If I had to guess I would say you have an EGR code. That code seems to come up often here on the board.
Yeah I suck at the spelling thing. I'm an accountant by trade, my wife is a writer so she usually proofs my stuff. She's just better off not knowing about how much time I spend here and on ski forumns. Thanks for the bump!
So I don't have to go out to the truck and get the huge book, the EGR code is?
The oil pressure and temps are great. I think I pass a Auto Zone close the the cabin. If it's not too late I'll stop in and have them pull the code. I'd rather not spend the vacation under the hood, so hopefully it's a simple item that can wait until Monday.
Thanks!
Most autoparts stores can read the codes for you, not just autozone. CEL has to do with emissions systems, so it will be one of the sensors or wiring to one of the sensors. Not neccesarily that big of a deal if everything else is OK (fluids/temps). It may go into "limp home" mode, because the sensors are not reading right, but it should be safe to drive.
The EGR codes are P0401 & P0402 for an OBDII vehicle depending on too little or too much flow through the EGR valve. P0401 (too little) is the most common as it happens if the rubber hoses under your intake crack - or the VSV valve goes out - or two or three other conditions that can be determined by going through the procedure in the FSM. If it is indeed a P0401 (which is definitely a suspect ) you can drive it for years with no adverse affects (well maybe the exception of inspection time.) I can only say that with confidence since I ran with one for 3 or 4 years before fixing it. YMMV
It depends on what your '94 is. Check your sticker in the engine compartment to see if OBD1 or OBD2. If OBD1, like my '94, you have to pull the codes yourself with a paper clip. Instructions are here:
Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
Print & save for future use. Sounds to me like you could just wait till you return, if 02 sensor or EGR - you'll just have worse gas mileage. But pull code before you go so you'll know.
Do a search on here of P0401. That's the one that most people get and it drives us Cali guys up a wall because of our inspections which you likely don't have. If it is the P0401 just wait until you have time to mess with it as you won't see any adverse effects. I would drive it in your situation. Just my 2 cents.
x2, most likley its ODBI and not II. Follow the link above, its simple. Just use a paper clip and count the flash from the CEL light on the dash. If it is ODBI dont buy any tool, its a $30 paperclip.
Your most likely fine driving it with a solid CEL light, but check.
Ok, I'm looking for a little RTH. My 80 ('93 OBD1) threw a code 21 (O2 Sensor1) while my wife was at her mom's yesterday. SHe just got back tonight and I was able to pull the code. I'm supposed to drive ~4 hours to Idaho in the morning. Can someone confirm to me that I'm ok driving it with a bad O2 Sensor? I'll try to get it replaced next week. Sorry for the hijack but at least its sort of on topic
Yes, you will be fine.
Drove for 2 years with bad O2 sensor and CEL light on.
It won't be operating at its most efficient state, but should be safe to drive.
