- Thread starter
- #21
Are those wireless headphones?
Nah, just a little ear protection for when I let the big guns loose
YouTube - Nathan Airchime K3HA Shop Test
That's slick.
How big are those speakers?
Regarding how much the receiver stick out in the dash against the OEM HU, I told you, is a lot.
Heyco watertight plugs???????????????????????
what are those and why do I want them?
I'm actually working on a fix for this
There's still a bit of room behind the HU, so I'm gunna weld a center section onto another set of OEM brackets and drill new holes about half inch back to pull the HU flush with the trim![]()
Yes, it has the little cooling fan behind it
I'm guessing it's heat activated cause when I did a bench test it didn't turn on
As for the screen, the position is fine and I sometimes tilt it up one notch on angle adjustment if I'm sitting upright...
Don't have any problems with glare, but then again, I'm running limo tint on top of the factory tint![]()
The fan should work only with the switch at the ignition position but not at the accesory position, as I guess you tested. It's very quiet but you can feel when on.
Please let me know if you were capable of moving it deeper inside the dash and post a picture.
Who is the maker of the flip downs you installed? I really like that idea-you said $100 each on ebay?
I really like the rack as well-the vid on youtube w/ the horn blasts makes me giggle-the neighbors must love you on fourth of July
