A little 80 advice needed
Trollhole
THC
Supporting Vendor
Moderator
Mauldin, SC
Website
forum.ih8mud.com
Here is my delimea.
I'm in the hunt for an 80/450 series with lockers and the newer engine.
My main purpose will be as a daily driver with the ocational 4hr drive into the mountains. Looking to pay around 7-14k
I've have a fellow club member who has a 97 40th anv for sale with lockers.
History
255k
engine replaced with a new long block at 105k so this engine has 150k on it.
no leaks
body has a few dents and dings
interior is about normal for this age (wood trim faded seats starting to crack)
Runs great.
Uses about 1/2 quart of oil every oil change
Tranny is unknown but shifts fine and fluid is clean.
There is a whine from one of the thirds. So that will have to be gone through
Front end has an issue with wandering. All tie rods have been replaced so really only thing left is castor bushings?
There is a pretty good vibration upon deceration.
Also has a good vibration aroun 80mph.
No rust
Engine light is on. Was told (toyota Tech) the egr system needed to be cleaned and a sensor replaced.
ABS light is on. Told (toyota Tech) it was the sensors in the back had metal fragments in them and needed to be cleaned.
Front axle was just rebuilt minus 3rd.
no records except for the reciept for the long block and engine work. (5k)
My question. Is it worth 7k? I've got around 3-5k I can dump into it. But is it worth putting that kind of cash in a vehicle with this kind of milage?
IMO, I think for 7k you can find one with less issues if you're patient.
marshall--
is that the one in aiken?
Does it have a lift on it? (per caster problems)
if it is lifted, the vibrations could be a result of the new castor */ adj. driveline
if its is not lifted i might take a look at the u-joints for slop/wear
dunno bout the egr or ABS stuff
I wish i could help you more, but my thoughts are that every part, bushing etc has seen 255k miles of use. There might be lots of rubber parts wanting to be replaced soon but as most of these rigs are getting to the 100-150k mark they cant be guarunteed not to be an issue on others, maybe just more imminent on this one.
several have shown up around 10K locked under 150k without these issues
I would hold out Marshall. I paid not much more than that for the Avocado...patience is your friend.
You can find 95's here in Socal for $8000-$9000. Most will have 150k on the clock, but they're mostly soccer mom freeway miles. Almost all of them have never been wheeled and they're rust free.
Buy it, ship it, PM it, do the axles, send in the injectors, change the headgasket and then drive the snot out of it until something needs fixing.
That should run you about $2k-$3k. So for about $10-$13K, you have a solid 80.
And then the mods....
