A good carburetor
Belmont, California
I have a 350V engine, and I'm going to also replace my carburator. My brother who works with and deals with muscle cars recommended a Holly Carb. Now I know that driving a muscle car isn't the same as off roading, and one needs to keep in mind the steep angles and articulation the FJ40 would be climbing or decending when choosing the correct carburator (if it matters). What does the experienced owners on this panel recommend?:confused:
Also, Sandrat62 wants to know what is better, plastic or stainless tire valve stem caps.:doh:
Steep hills, bumps and Holley carbs. You can choose any two. Some say it's a fixable problem with an offroad kit from Holley.
I had the problem mentioned below with my Holley. I went back to a rebuilt stock carb. It only happened when I was in a precarious spot too. No fun.
http://www.rzeppa.org/tech/carb.htm
I see your running a 350SBC That makes the choices out of my range. I ran a holley for a while with my F and it was not the best choice. Sucked on trails. Went back to the original carb and no issues. I was a drag racer in my youth and thought the holley was an upgrade. Live and learn. Different situations, different applications. I've heard the rodchester quadraflops are pretty good but do not take my word...
Save yourself some time and money.
Go TBI EFI.
Make sure to either take the time to do it RIGHT
or
buy a harness and kit from Howell or one of other EFI vendors.
put a coffee can on your roof connect it to a rubber hose going to your engine. then fill the can with gas. remember gravity is your friend!:flipoff2: :flipoff2: :flipoff2:
Didn't they do that on Junkyard Wars?
I know it will not be the most popular comment to make, but you asked for real world experience. I have a SBC 350 and run an "electric" choke Edelbrock Performer carb I have had good luck with for offroading (once setup). driven some pretty steep and slooooow up and down and no issue with stalling. Biggest issue is you really need to have a well versed carb person set it up correctly rather than just buy and slap on. The PO just slapped on and performance was poor. I took it to a carb guy and he checked and adjusted the floats, needles (which were thrashed by debris from the unclean fuel tank and bad old filters until I fized all of that), seats, jets, and fine tuned it using his mumbo jumbo diagnostic tube up the muffler device... and the performance was better, engine temp a little lower and we also found the fuel pump was a bit strong for this carb so I put an inline regulator in and all seems well for me.
just my .03 cents
I vote stainless... or ones that look like dice are even better :)
Also assuming that because this will be used for short bursts and slow speeds, a two barrel should do a better job than a 4.
I personally own an Edelbrock Performer with the offroad kit.
did not know they had an offroad kit for the EB Performer.... I have seen it for others, but not for the EBP?
I'll have to do some investigating, but for now the stock two barrel carb will do. And thanks sandrat for making things easy for me to understand. Your my best friend:).
