- Thread starter
- #21
Note the black plastic plugs from the holes Rust Check drilled:
Cosmoline and fluid film/wool wax both have their advantages, so from what I’ve come to learn, I’d say the best bet is using both in the areas of their strengths. Short version IMO, fluid film creeps and gets everywhere, like you said, so it’s good in tight spots with seams/etc, inside frame & other cavities, while cosmoline creates a more durable and perhaps better-in-general rust proofing, so it can be used over the main surfaces, although it takes more prep cleaning to be done properly. I actually just fluid filmed my whole truck today, including inside the frame, but have not used cosmoline yet. I do use a similar CRC product & boeshield T9 for my outboard & kicker, both of which work fantastically.
Not quite as salt-gnarly here, but I’m in the equal but opposite corner from you, in southeast AK. Same deal with winter - it doesn’t stay below freezing and is always wet. I know they sometimes use road treatment here, but luckily it seems that they often just use simple gravel. Vehicles definitely rust, but not like what you see from the rust belt proper.
My last XJ was losing its floor pans, and had a rotten unibody frame above the rear axle. My 80 has zero issues, fortunately. I do the whole truck before winter, and then touch up the rear half in spring before boat season starts. I don’t dunk the truck when I launch, but it’s extra protection.
Project Farm also has a couple great videos comparing all these products
