- Thread starter
- #21
You have the right idea - including the load distribution system. Yes, I know that Toyota does not recommend them on a stock setup. However, Toyota also did not include a trailer braking system.
Airbags alone are a false assurance. They fix the 'look' but actually decrease the stability by raising the fulcrum point (rear axle) without adding any additional downforce to the front axle. The front axle lift from a heavy hitch decreases handling and can cause the front wheels to skid & skip around during turning and can be outright dangerous at highway speeds. Just jacking up the rear end to compensate for height lost to trailer tongue weight does nothing to solve the then unloaded front axle.
A properly set up load distribution system pushes that downforce from the rear wheels forward to the front axle and helps keep it on the ground. The rear end comes up a bit, the front end goes down a lot. The drawback is that it gives a false unloaded signal to the LSPV as the vehicle is 'flat'. Having a properly set up trailer brake controller and good trailer brakes counters the LSPV drawback significantly.
Either way, the end result is outside of specs for an 80 series US Land Cruiser. You're crossing into that realm of your own choosing and should weigh advice accordingly. None of us are going to pick up the bill if/when your rig jack knifes (unloaded front axle) or breaks (too much weight on one or both axles).
Grench- with a SWAY control bar, do you still be crosswinds will be a major issue and or jackknifing?? I've got a good electric break system set up and plan to upgrade the pads on the LC and camper before I hit the road.
